So this is part 3 in a series of threads I’ve been posting to try and get a CRS-309 working as I’d expect and I’m hoping it is indeed the last one I need to post for a while - but thank you to folks like @mkx, @anav & @tdw for educating this noob. To begin with here is a visual that shows my overall network architecture, which allows clients behind the CRS-309 to obtain a IP from the CCR-1009 in a specific VLAN:
Zooming into the CRS-309 itself, there are currently two clients connected to the switch as shown in the visual below:
Here is the config export from the CRS-309 that is represented by the visual above:
add admin-mac=2C:C8:1B:20:06:C8 auto-mac=no comment="Clients Bridge" name=\
bridge1 protocol-mode=mstp vlan-filtering=yes
set [ find default-name=ether1 ] l2mtu=1592
set [ find default-name=sfp-sfpplus1 ] l2mtu=1592
set [ find default-name=sfp-sfpplus2 ] l2mtu=1592
set [ find default-name=sfp-sfpplus3 ] l2mtu=1592
set [ find default-name=sfp-sfpplus4 ] l2mtu=1592
set [ find default-name=sfp-sfpplus5 ] l2mtu=1592
set [ find default-name=sfp-sfpplus6 ] l2mtu=1592
set [ find default-name=sfp-sfpplus7 ] l2mtu=1592
set [ find default-name=sfp-sfpplus8 ] comment="MikroTik CCR1009 Uplink" \
l2mtu=1592
/interface bonding
add mode=802.3ad name=bond-sfpp2_sfpp3 slaves=\
sfp-sfpplus2,sfp-sfpplus3
add bridge=bridge1 interface=sfp-sfpplus1 pvid=104
add bridge=bridge1 interface=sfp-sfpplus8
add bridge=bridge1 interface=bond-sfpp2_sfpp3 pvid=104
/interface bridge vlan
add bridge=bridge1 tagged=sfp-sfpplus8 vlan-ids=104
add bridge=bridge1 tagged=sfp-sfpplus8,bond-sfpp2_sfpp3 vlan-ids=50
add bridge=bridge1 tagged=sfp-sfpplus8,bond-sfpp2_sfpp3 vlan-ids=20
add address=192.168.48.10/24 interface=bridge1 network=192.168.48.0
set servers=192.168.48.254
add distance=1 gateway=192.168.48.254
/system clock
set time-zone-autodetect=no time-zone-name=Asia/Singapore
/system clock manual
set time-zone=+08:00
/system identity
set name="MikroTik CRS309-1G-8S+"
/system ntp client
set enabled=yes server-dns-names=0.sg.pool.ntp.org,1.sg.pool.ntp.org
/system routerboard settings
set boot-os=router-os
This is the config for the CCR-1009:
add admin-mac=4C:5E:0C:03:20:22 auto-mac=no fast-forward=no name=\
"All Ports Bridge" protocol-mode=mstp vlan-filtering=yes
set [ find default-name=ether1 ] name="ether1-switch master" speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] comment="Unifi US-24 RJ45 SFP Uplink-1" \
speed=100Mbps
set [ find default-name=ether6 ] comment="Unifi US-24 RJ45 SFP Uplink-2" \
mac-address=4C:5E:0C:03:20:26 speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=ether8 ] advertise=100M-full,1000M-full comment=\
"WAN Interface" name=ether8-gateway speed=100Mbps
set [ find default-name=sfp-sfpplus1 ] advertise=\
10M-full,100M-full,1000M-full,10000M-full comment=\
"MikroTik CRS309-1G-8S+ Fibre SFP+ Uplink"
set [ find default-name=sfp1 ] advertise=10M-full,100M-full,1000M-full \
mac-address=4C:5E:0C:03:20:22
/interface vrrp
add authentication=ah comment="VLAN 1 Network" interface="All Ports Bridge" \
name=mgmt-net-vrrp priority=250 version=2 vrid=48
/interface vlan
add comment="DMZ network" interface="All Ports Bridge" name=dmz-net vlan-id=\
122
add comment="Guest network" disabled=yes interface="All Ports Bridge" name=\
guest-net vlan-id=90
add comment="IOT Devices network" interface="All Ports Bridge" name=iot-net \
vlan-id=50
add comment="Lab network" interface="All Ports Bridge" name=lab-net vlan-id=\
54
add comment="Untrusted Client(s) network" interface="All Ports Bridge" name=\
others-net vlan-id=75
add comment="Server network" interface="All Ports Bridge" name=server-net \
vlan-id=20
add comment="\"Trusted\" Clients network" interface="All Ports Bridge" name=\
trusted-clients-net vlan-id=104
/interface bonding
add comment="Unifi US-24 Trunk Ports" lacp-rate=1sec mode=802.3ad name=\
bond-ether5_ether6 slaves=ether5,ether6
/interface vrrp
add authentication=ah interface=dmz-net name=dmz-net-vrrp priority=250 \
version=2 vrid=122
add authentication=ah interface=iot-net name=iot-net-vrrp priority=250 \
version=2 vrid=50
add authentication=ah interface=lab-net name=lab-net-vrrp priority=250 \
version=2 vrid=54
add authentication=ah interface=others-net name=others-net-vrrp priority=250 \
version=2 vrid=75
add authentication=ah interface=server-net name=server-net-vrrp priority=250 version=2 vrid=20
add authentication=ah interface=trusted-clients-net name=trusted-clients-vrrp priority=250 version=2 vrid=104
add name=WAN-All
add name=LAN
add name=WAN-Native
/ip dhcp-server option
add code=15 name=labdomain value="'lab.domain.tld'"
add code=119 name=domainsearch value=\
"s'srv.domain.tld,clients.domain.tld,lab.domain.tld'"
add code=15 name=clientdomain value="'clients.domain.tld'"
add code=15 name=srvdomain value="'srv.domain.tld'"
add code=15 name=mgmtdomain value="'mgmt.domain.tld'"
add code=15 name=iotdomain value="'iot.domain.tld'"
/ip dhcp-server option sets
add name=lab-dhcp-options options=labdomain,domainsearch
add name=client-dhcp-options options=clientdomain,domainsearch
add name=srv-dhcp-options options=srvdomain,domainsearch
add name=mgmt-dhcp-options options=mgmtdomain
add comment="Management IP Range" name=mgmt-iprange ranges=\
192.168.48.100-192.168.48.200
add comment="IP Range for Lab Network" name=lab-iprange ranges=\
192.168.54.192-192.168.54.230
add comment="IP Range for direct attached clients" name=direct-iprange \
ranges=192.168.88.10-192.168.88.20
add comment="IP Range for Servers" name=server-iprange ranges=\
192.168.20.20-192.168.20.100
add comment="IP range for IOT network" name=iot-iprange ranges=\
192.168.50.20-192.168.50.50
add comment="IP Range for untrusted clients" name=others-iprange ranges=\
192.168.75.20-192.168.75.30
add comment="IP Range for Guest Network" name=guest-iprange ranges=\
192.168.90.10-192.168.90.20
add comment="IP Range for \"trusted\" clients" name=trusted-iprange ranges=\
192.168.104.100-192.168.104.200
add comment="IP Range for external facing hosts" name=dmz-iprange ranges=\
192.168.122.90/31
add address-pool=mgmt-iprange disabled=no interface="All Ports Bridge" \
lease-time=1d name=mgmt-dhcp
add address-pool=lab-iprange disabled=no interface=lab-net lease-time=1h name=lab-dhcp
add add-arp=yes address-pool=server-iprange disabled=no interface=server-net \
lease-time=3d name=server-dhcp
add address-pool=guest-iprange interface=guest-net lease-time=1h name=\
guest-dhcp
add address-pool=iot-iprange disabled=no interface=iot-net lease-time=1d name=iot-dhcp
add address-pool=others-iprange disabled=no interface=others-net lease-time=\
12h name=others-dhcp
add add-arp=yes address-pool=trusted-iprange disabled=no interface=\
trusted-clients-net lease-time=1d name=trusted-dhcp
add address-pool=dmz-iprange disabled=no interface=dmz-net lease-time=1d \
name=dmz-dhcp
/queue type
set 5 pcq-limit=1000KiB pcq-total-limit=1000KiB
set 6 pcq-limit=5000KiB pcq-total-limit=5000KiB
/queue simple
add burst-limit=5M/25M burst-threshold=5M/25M burst-time=5s/10s max-limit=\
3M/20M name=others-net-queue queue=ethernet-default/ethernet-default \
target=192.168.75.0/24 total-queue=ethernet-default
add burst-limit=2M/5M burst-threshold=2M/5M burst-time=5s/5s limit-at=256k/1M \
max-limit=1M/3M name=guest-net-queue queue=\
ethernet-default/ethernet-default target=guest-net
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/system logging action
add disk-file-count=4 disk-file-name=disk1/log disk-lines-per-file=2000 name=\
sdcard target=disk
add bridge="All Ports Bridge" interface="ether1-switch master"
add bridge="All Ports Bridge" interface=ether2
add bridge="All Ports Bridge" interface=ether3 pvid=104
add bridge="All Ports Bridge" interface=ether4
add bridge="All Ports Bridge" comment="MikroTik CRS309-1G-8S+ Uplink" \
add bridge="All Ports Bridge" interface=sfp1
add bridge="All Ports Bridge" interface=ether7
add bridge="All Ports Bridge" comment="Unifi US-24 Trunk Ports" interface=\
bond-ether5_ether6
set discover-interface-list=!WAN-All
add bridge="All Ports Bridge" comment="\"Trusted\" Clients network" tagged="Al\
l Ports Bridge,ether1-switch master,ether2,ether3,ether4,sfp1,sfp-sfpplus1\
,ether7,bond-ether5_ether6,trusted-clients-net" vlan-ids=104
add bridge="All Ports Bridge" comment="DMZ network" tagged="All Ports Bridge,e\
ther1-switch master,ether2,ether3,ether4,sfp1,sfp-sfpplus1,ether7,bond-eth\
er5_ether6,dmz-net" vlan-ids=122
add bridge="All Ports Bridge" comment="IOT Devices network" tagged="All Ports \
Bridge,ether1-switch master,ether2,ether3,ether4,sfp1,sfp-sfpplus1,ether7,\
bond-ether5_ether6,iot-net" vlan-ids=50
add bridge="All Ports Bridge" comment="Server network" tagged="All Ports Bridg\
e,ether1-switch master,ether2,ether3,ether4,sfp1,sfp-sfpplus1,ether7,bond-\
ether5_ether6,server-net" vlan-ids=20
add bridge="All Ports Bridge" comment="Lab network" tagged="All Ports Bridge,e\
er5_ether6,lab-net" vlan-ids=54
add bridge="All Ports Bridge" comment="Untrusted Client(s) network" tagged="Al\
,ether7,bond-ether5_ether6,others-net" vlan-ids=75
add bridge="All Ports Bridge" tagged=*2A vlan-ids=1
/interface detect-internet
set detect-interface-list=WAN-All internet-interface-list=WAN-Native \
lan-interface-list=LAN wan-interface-list=WAN-All
add interface=ether8-gateway list=WAN-All
add interface="All Ports Bridge" list=LAN
add interface=bond-ether5_ether6 list=LAN
add interface=dmz-net list=LAN
add interface="ether1-switch master" list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=guest-net list=LAN
add interface=iot-net list=LAN
add interface=others-net list=LAN
add interface=server-net list=LAN
add interface=trusted-clients-net list=LAN
add interface=lab-net list=LAN
add interface=dmz-net-vrrp list=LAN
add interface=iot-net-vrrp list=LAN
add interface=mgmt-net-vrrp list=LAN
add interface=others-net-vrrp list=LAN
add interface=server-net-vrrp list=LAN
add interface=lab-net-vrrp list=LAN
add interface=trusted-clients-vrrp list=LAN
add interface=l2tp-evpn-IN list=WAN-All
add interface=l2tp-evpn-US list=WAN-All
add interface=ether8-gateway list=WAN-Native
add address=192.168.48.1/24 comment="Management network" interface=\
"All Ports Bridge" network=192.168.48.0
add address=192.168.54.1/24 comment="Lab Network" interface=lab-net network=\
192.168.54.0
add address=192.168.20.1/24 comment="Server Network" interface=server-net \
network=192.168.20.0
add address=192.168.50.1/24 comment="IOT Network" interface=iot-net network=\
192.168.50.0
add address=192.168.75.1/24 comment="Untrusted Clients" interface=others-net \
network=192.168.75.0
add address=192.168.90.1/24 comment="Guest Network (Inactive)" disabled=yes \
interface=guest-net network=192.168.90.0
add address=192.168.104.1/24 comment="Trusted Clients" interface=\
trusted-clients-net network=192.168.104.0
add address=192.168.122.1/24 comment="DMZ Network" interface=dmz-net network=\
192.168.122.0
add address=192.168.54.254 interface=lab-net-vrrp network=192.168.54.254
add address=192.168.20.254 interface=server-net-vrrp network=192.168.20.254
add address=192.168.48.254 interface=mgmt-net-vrrp network=192.168.48.254
add address=192.168.50.254 interface=iot-net-vrrp network=192.168.50.254
add address=192.168.75.254 interface=others-net-vrrp network=192.168.75.254
add address=192.168.104.254 interface=trusted-clients-vrrp network=\
192.168.104.254
add address=192.168.122.254 interface=dmz-net-vrrp network=192.168.122.254
add address=192.168.50.19 interface=iot-net network=192.168.50.19
add address=192.168.75.19 interface=others-net network=192.168.75.19
/ip arp
add address=192.168.48.255 comment="Broadcast MAC for WOL" interface=\
bond-ether5_ether6 mac-address=FF:FF:FF:FF:FF:FF
add address=192.168.48.51 interface=bond-ether5_ether6 mac-address=\
FC:EC:DA:3A:96:66
add address=192.168.48.50 interface=bond-ether5_ether6 mac-address=\
FC:EC:DA:3A:9A:8B
/ip cloud
set update-time=no
/ip dhcp-client
add disabled=no interface=ether8-gateway use-peer-dns=no use-peer-ntp=no
add interface=sfp1
/ip dhcp-server lease
add address=192.168.48.10 comment=\
"10Gbe Study Switch (Mikrotik CRS309-1G-8S+)" mac-address=\
2C:C8:1B:20:06:C9
add address=192.168.20.0/24 comment="Server VLAN IP Pool" dhcp-option-set=\
srv-dhcp-options dns-server=192.168.20.254 domain=srv.domain.tld \
gateway=192.168.20.254
add address=192.168.48.0/24 comment="Management IP Pool" dhcp-option-set=\
mgmt-dhcp-options dns-server=192.168.48.254 domain=mgmt.domain.tld \
gateway=192.168.48.254 netmask=24
add address=192.168.50.0/24 comment="IOT VLAN IP Pool" dhcp-option=iotdomain \
dns-server=192.168.50.19 domain=iot.domain.tld gateway=192.168.50.254
add address=192.168.54.0/24 comment="Lab VLAN IP Pool" dhcp-option-set=\
lab-dhcp-options dns-server=192.168.54.230 domain=lab.domain.tld \
gateway=192.168.54.254
add address=192.168.75.0/24 comment="Others VLAN IP Pool" dns-server=\
192.168.75.19 gateway=192.168.75.254
add address=192.168.90.0/24 comment="Guest VLAN IP Pool (Inactive)" \
dns-server=8.8.8.8 gateway=192.168.90.1
add address=192.168.104.0/24 comment="\"Trusted\" VLAN IP Pool" \
dhcp-option-set=client-dhcp-options dns-server=192.168.104.254 domain=\
clients.domain.tld gateway=192.168.104.254
add address=192.168.122.0/24 comment="DMZ VLAN IP Pool" dns-none=yes gateway=\
192.168.122.254
set allow-remote-requests=yes servers=9.9.9.9,208.67.220.222
/ip dns static
add address=192.168.88.1 name=router.lan ttl=1w3d
add address=192.168.20.1 name=ccr1009-router.srv.domain.tld ttl=1w3d
add address=192.168.50.1 name=ccr1009-router.iot.domain.tld ttl=1w3d
add address=192.168.54.1 name=ccr1009-router.lab.domain.tld ttl=1w3d
add address=192.168.75.1 name=ccr1009-router.others.domain.tld ttl=1w3d
add address=192.168.104.1 name=ccr1009-router.clients.domain.tld ttl=1w3d
add address=192.168.122.1 name=ccr1009-router.dmz.domain.tld ttl=1w3d
add address=192.168.20.254 name=router.srv.domain.tld ttl=1w3d
add address=192.168.50.254 name=router.iot.domain.tld ttl=1w3d
add address=192.168.54.254 name=router.lab.domain.tld ttl=1w3d
add address=192.168.75.254 name=router.others.domain.tld ttl=1w3d
add address=192.168.104.254 name=router.clients.domain.tld ttl=1w3d
add address=192.168.122.254 name=router.dmz.domain.tld ttl=1w3d
## Firewall rules need to be reworked!!
/ip firewall address-list
add address=192.168.88.2 comment="Exclude from PCC Example" disabled=yes \
list="Exclude from PCC"
add address=0.0.0.0/8 comment=RFC6890 list=NotPublic
add address=10.0.0.0/8 comment=RFC6890 list=NotPublic
add address=100.64.0.0/10 comment=RFC6890 list=NotPublic
add address=127.0.0.0/8 comment=RFC6890 list=NotPublic
add address=169.254.0.0/16 comment=RFC6890 list=NotPublic
add address=172.16.0.0/12 comment=RFC6890 list=NotPublic
add address=192.0.0.0/24 comment=RFC6890 list=NotPublic
add address=192.0.2.0/24 comment=RFC6890 list=NotPublic
add address=192.168.0.0/16 comment=RFC6890 list=NotPublic
add address=192.88.99.0/24 comment=RFC3068 list=NotPublic
add address=198.18.0.0/15 comment=RFC6890 list=NotPublic
add address=198.51.100.0/24 comment=RFC6890 list=NotPublic
add address=203.0.113.0/24 comment=RFC6890 list=NotPublic
add address=224.0.0.0/4 comment=RFC4601 list=NotPublic
add address=240.0.0.0/4 comment=RFC6890 list=NotPublic
add address=192.168.48.0/24 comment="Critical LAN Network Ranges" list=\
Sensitive-Internal
add address=192.168.20.0/24 comment="Critical LAN Network Ranges" list=\
Sensitive-Internal
add address=192.168.122.0/24 comment="Critical LAN Network Ranges" list=\
Sensitive-Internal
add address=192.168.50.21 comment="IOT Devices with DNS Whitelist" list=\
IOT-Whitelist
add address=192.168.50.22 comment="IOT Devices with DNS Whitelist" list=\
IOT-Whitelist
add address=192.168.54.226 comment="Lab DNS Whitelist" list=Lab-Whitelist
add address=192.168.104.0/24 comment="Client LAN Network Ranges" list=\
Client-LAN
add address=192.168.50.0/24 comment="Client LAN Network Ranges" list=\
Client-LAN
add address=192.168.75.0/24 comment="Non-default Client Networks" list=\
External-Client
add address=192.168.90.0/24 comment="Non-default Client Networks" list=\
External-Client
established,related,untracked
invalid
connection-state=invalid
connection-state=new in-interface-list=WAN-All
add action=drop chain=input comment="Block Winbox connections on WAN" \
dst-port=8291 in-interface=ether8-gateway protocol=tcp
"Block Mikrotik Bandwidth Test connections on WAN" dst-port=2000 \
add action=drop chain=input comment="Drop inbound TCP DNS" dst-port=53 \
add action=drop chain=input comment="Drop inbound UDP DNS" disabled=yes \
dst-port=53 in-interface=ether8-gateway protocol=udp
"Drop all packets which does not have unicast source IP address" \
src-address-type=!unicast
add action=drop chain=input comment="Drop all packets from public internet whi\
ch should not exist in public network" in-interface-list=WAN-All \
src-address-list=NotPublic
add action=fasttrack-connection chain=forward connection-state=\
established,related dst-address-list=!External-Client src-address-list=\
!External-Client
add action=drop chain=forward log-prefix=DMZ protocol=tcp src-address=\
192.168.122.90 src-port=!443
add action=drop chain=forward comment="Drop all packets from public internet w\
hich should not exist in public network" in-interface-list=WAN-All \
add action=drop chain=forward comment="Drop all packets in local network which\
\_does not have local network address" in-interface-list=LAN src-address=\
!192.168.0.0/16
add action=drop chain=forward comment="Drop all packets from local network to \
internet which should not exist in public network" disabled=yes \
dst-address-list=NotPublic in-interface-list=LAN
"Block IOT Traffic to critical LAN Segments" connection-state=\
invalid,new,untracked dst-address-list=Sensitive-Internal in-interface=\
iot-net log=yes log-prefix=iot-drop src-mac-address=!90:DD:5D:CA:59:A7
add action=drop chain=input comment="drop all from WAN" in-interface=\
ether8-gateway
out-interface-list=WAN-All
add disabled=yes distance=1 dst-address=192.168.88.0/24 gateway=\
"All Ports Bridge" routing-mark=wan1
"All Ports Bridge" routing-mark=wan2
add disabled=yes distance=1 gateway=ether7
add disabled=yes distance=1 gateway=ether8-gateway
add comment="VPN TCP" distance=1 dst-address=192.168.126.0/24 gateway=\
192.168.48.174
add comment="VPN UDP" distance=1 dst-address=192.168.166.0/24 gateway=\
192.168.48.174
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.0.0/16
set ssh address=192.168.0.0/16
set api address=192.168.0.0/16
set winbox address=192.168.0.0/16
set api-ssl address=192.168.0.0/16
/ip ssh
set always-allow-password-login=yes forwarding-enabled=remote strong-crypto=\
yes
/ip upnp interfaces
add interface=ether8-gateway type=external
add interface="All Ports Bridge" type=internal
add interface=bond-ether5_ether6 type=internal
/lcd
set backlight-timeout=10m default-screen=stat-slideshow time-interval=hour
/lcd interface
set sfp1 disabled=yes
/routing filter
add chain=dynamic-in distance=3 set-routing-mark=wan1
add chain=dynamic-in distance=4 set-routing-mark=wan2
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=trusted-clients-vrrp upstream=yes
/routing igmp-proxy mfc
add downstream-interfaces=trusted-clients-net group=239.255.255.250 source=\
192.168.104.108 upstream-interface=iot-net
add downstream-interfaces=trusted-clients-net group=224.0.0.1 source=\
add downstream-interfaces=trusted-clients-net group=224.0.0.251 source=\
/system clock
set time-zone-name=Asia/Singapore
/system health
set cpu-overtemp-threshold=110C
/system identity
set name="MikroTik CCR1009 Router (Primary)"
/system leds
set 0 interface=sfp-sfpplus1
set 1 interface=sfp-sfpplus1
set 2 interface=sfp1
/system logging
set 0 action=sdcard
set 1 action=disk
set 2 action=disk
add action=sdcard topics=script
add action=disk topics=interface
add action=disk topics=critical
add disabled=yes topics=debug
/system ntp client
/tool graphing interface
add allow-address=192.168.0.0/16 interface=ether8-gateway
add allow-address=192.168.48.0/24 interface=bond-ether5_ether6
add allow-address=192.168.104.0/24 interface=bond-ether5_ether6
add allow-address=192.168.88.0/24 interface="All Ports Bridge"
/tool graphing resource
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
The behavior I’m seeing is as follows:
- Both Client A and Client C (in the visual above) can get an DHCP IP in the 192.168.104.0/24 range
- Both can route to the Internet (accessing other hosts in different VLAN’s is an issue)
- When I try to run a iperf3 test between Client A & Client C, I can see that the bandwidth is maxing out at 1 Gbps and all the traffic is at the SFP+ port on the CCR-1009, suggesting that even intra-subnet traffic is going to the Router instead of staying on the switch.
Screenshots:
IP address of Client A in 192.168.104.0/24 subnet:
IP address of Client C in 192.168.104.0/24 subnet:
Screenshot of iPerf3 command from Client A:
Screenshot of CRS-309 Winbox during iPerf3 test - note the traffic is between SFP1 (Client A) and SFP8 (Uplink to CCR-1009):
Screenshot of CCR-1009 during iPerf3 test - notice the traffic is all on SFP1 (Patch port for CRS-309):
Screenshot of iPerf3 results from Client C running iPerf3 server:
I also noticed that Client C is unable to ping any hosts outside of it’s VLAN and indeed it cannot even ping the CCR-1009 on the router’s VLAN address in the 192.168.104.0/24 subnet. Screenshot of ping failure:
However, I found interesting that Wireshark shows that the router is indeed responding to the ping but it’s not reaching the client:
I’d appreciate if folks can provide me with some insights into why this happening.
