Clients cannot reach networks through Wireguard tunnel but router can
I using Mikrotik products for a long time and I do have another site with a similar config, but this time I do not find the error
Basics: main site with multiple VLANs and a OPNSense Firewall acting as wireguard server.
I need to reach 192.168.206.0/24 and 172.23.1.0/24 and 10.113.7.0/24 on the main site, the wireguard net is 10.10.10.0/24 (wg server is 10.10.10.1)
I bought a D53G-5HacD2HnD set up as wireguard client connecting to main site as client IP 10.10.10.13
There’ll be 2 clients on the LTE site, they need to access the VLANs on the main site. A real “site to site” is not needed, masquerading will do.
The prolem: after setting up everything and testing from winbox/CLI the router is able to reach everything.
Now I connect a client to ether5 (my test port), the client reaches everything EXCEPT the wg_net and the nets 192.168.206.0/24 and 172.23.1.0/24 and 10.113.7.0/24
And … this will be a small error hiding in plain sight, but I don’t get it.
# apr/27/2023 08:29:51 by RouterOS 7.8
# software id = K95U-DUDN
# model = D53G-5HacD2HnD
# serial number = HD508964DBW
add admin-mac=18:FD:74:A8:EA:B1 auto-mac=no comment=defconf frame-types=\
    admit-only-untagged-and-priority-tagged ingress-filtering=no name=bridge \
    vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=estonia disabled=no distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid=MikroTik-A8EAB6 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=estonia disabled=no distance=indoors frequency=\
    auto installation=indoor mode=ap-bridge ssid=MikroTik-A8EAB7 \
/interface wireguard
add listen-port=51820 mtu=1420 name=wg_if
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=web.vodafone.de use-network-apn=yes
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=web.vodafone.de \
    band="" nr-band=""
/ip hotspot profile
add address-pool=default-dhcp interface=ether5 name=defconf
add bridge=bridge comment=defconf frame-types=\
    admit-only-untagged-and-priority-tagged ingress-filtering=no interface=\
    ether1 pvid=316
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge ingress-filtering=no interface=*A
add bridge=bridge interface=*10
add bridge=bridge interface=*11
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge tagged=*A vlan-ids=300
add bridge=bridge tagged=*A vlan-ids=316
add bridge=bridge tagged=*A vlan-ids=821
add bridge=bridge tagged=*A vlan-ids=909
add bridge=bridge tagged=*A vlan-ids=940
add bridge=bridge tagged=*A vlan-ids=399
add bridge=bridge tagged=*A vlan-ids=102
add comment=defconf interface=lte1 list=WAN
add interface=ether5 list=LAN
add interface=wg_if list=LAN
/interface wireguard peers
add allowed-address=\
    10.10.10.13/24,192.168.206.0/24,172.23.1.0/24,10.113.7.0/24 comment=\
    145.253.95.226 endpoint-address=145.253.95.226 endpoint-port=51820 \
    interface=wg_if persistent-keepalive=5s public-key=\
    "xxx"
add address=192.168.88.1/24 comment=defconf interface=ether5 network=\
    192.168.88.0
add address=10.10.10.13/24 interface=wg_if network=10.10.10.0
/ip dhcp-client
add add-default-route=no disabled=yes interface=*10 use-peer-dns=no \
    use-peer-ntp=no
add add-default-route=no disabled=yes interface=*D use-peer-dns=no \
    use-peer-ntp=no
    192.168.88.1
set allow-remote-requests=yes servers=192.168.206.37
/ip dns static
/ip firewall address-list
add address=192.168.88.0/24 list=reifenlager_subnet
add action=accept chain=forward in-interface=wg_if
    established,related,untracked
    invalid disabled=yes
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    in-interface-list=!LAN
add action=masquerade chain=srcnat dst-address=10.10.10.0/24 out-interface=\
    wg_if
add action=masquerade chain=srcnat dst-address=172.23.1.0/24 out-interface=\
    wg_if
add action=masquerade chain=srcnat dst-address=172.16.16.0/21 log=yes \
    log-prefix=masq out-interface=wg_if
add disabled=no dst-address=192.168.206.0/24 gateway=10.10.10.1 \
    routing-table=main suppress-hw-offload=no
add disabled=no dst-address=10.113.7.0/24 gateway=10.10.10.1 routing-table=\
add disabled=no dst-address=172.16.16.0/21 gateway=10.10.10.1 routing-table=\
add disabled=no dst-address=172.20.209.0/24 gateway=10.10.10.1 routing-table=\
add disabled=no distance=1 dst-address=172.20.240.0/24 gateway=10.10.10.1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
add disabled=no dst-address=172.23.1.0/24 gateway=10.10.10.1 routing-table=\
add disabled=no distance=1 dst-address=172.23.102.0/24 gateway=10.10.10.1 \
    target-scope=10
add disabled=no distance=1 dst-address=172.23.199.0/24 gateway=10.10.10.1 \
    target-scope=10
add disabled=no dst-address=172.24.0.0/16 gateway=10.10.10.1 routing-table=\
add disabled=no distance=1 dst-address=172.28.121.0/24 gateway=10.10.10.1 \
    target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/mpls ldp
add disabled=yes lsr-id=10.10.10.13 transport-addresses=10.10.10.13
/mpls ldp interface
add disabled=yes interface=wg_if
/snmp
set enabled=yes
/system clock
/system identity
set name=ReifenlagerRouter
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
