Clients Cards
MSI PC54G3
MSI PC60G
Encore ENLWI-G
Edimax EW7128G
Noganet TWL-542P
TP Link WN 650G
I have to select one of this cards to use in the clients PCs.
The distance is 300 - 500 meters from the omni
I have a RB whit a senao 400 mw and and omni antena in a big tower.
Which card is better ? Anyone know this cards ?
( my english is to bad, sorry )
This is close distance, so any card should work. I just wouldn’t use these MSI cards, I don’t have good experience from Asus WiFi cards, so I don’t recommend card from motherboard manufacturers, just stick to network equipment manufacturers. I have good experience with TP-Link cards.
Thanks, yes is too close.
But i ask because some cards maybe have some problems working whit MT
I use APs usually but in this case i need cards and have nio experience whit this.
Bye
If you are unsure, just use Atheros based cards, you can’t miss with this.
I am using TP-Link 650 and 651 cards, and I have quite a few of them.
I am very pleased.
651 is AR5213, 650 is AR5212.
Both good cards.
About the others, I just did not used them.
It is close distance, any card should do, but… I would strongly recomend using an ethernet wireless bridge instead of a pci or USB card, you get much more flexibiliti and reliability from an ethernet wireless bridge, something like a:
linksys wrt54g or a
wap54g, or an
exterasys wap 253 wap 254,
or any bridge based on the Realtek 8186 chipset (these are the cheapest ones and have good performance)
This way if you requiere LOS (Line of sigth) you just run a long UTP cable with power/ethernet, place the ethernet wireless bridge inside an exterior casing (you can make this out of 8 inch PVC tube and 2 PVC caps)
and you have your selfe an afordable and reliable outdoor antena
:smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp: :smiling_imp:
stay away from Encore, we had trouble with them
I want to use cards because the clients are soo close to the tower , and the installation in the client home will be more " clear ", only put the card in the pc and is running, so no cables, no holes in the wall or anything else.
Ok dude, your call, if you whant to go with the cards that’s fine, but make a test first, get a lap-top or a cpu with a card allredy installed and configured and check if you get a good link, if you get a good link… Congrat’s¡¡¡ but if you are not satisfied with the performance, get the ethernet wireless bridge.
Best Regards and good luck¡¡
James S.
We also using T-link in some of our clients that is as far as 1km
but i use a pigtail and a 13dbi flatpanel anntenna or for the close one
a 8dbi flatpanel
[> admin@G.I.Zone > Tower 1] interface wireless registration-table> print
INTE… RADIO-NAME MAC-ADDRESS AP SIGNAL… TX-RATE
0 ;;; 50-16 Sidney
wlan2 Squid Home 00:0B:6x:xx:xx:xx no -79dBm… 1Mbps
1 ;;; 50-50 floris
wlan3 > 00:14:78:7x:xx:xx > no -81dBm… 36Mbps
2 ;;; 50-40 Yarik
wlan2 > 00:14:78:7x:xx:xx > no -63dBm… 11Mbps
3 ;;; 40-22 Scriptscribe
wlan2 00:02:xx:xx:xx:xx no -95dBm… 36Mbps
4 ;;; 40-28 Jako
wlan3 00:02:6x:xx:xx:xx no -95dBm… 36Mbps
5 ;;; 50-130 Thinus
wlan3 00:30:4x:xx:xx:xx no -72dBm… 36Mbps
as the two in bold is TP-link
the frist one no 1 is 500m using a 8dbi flatpanel and no 2 is 1km but in a block of flats with LOS also 8dbi
no5 using a planet pci with a 13dbi with pigtail and 4m lm400 cable
Sidney
:sunglasses:
Thanks , this afternoon i will try whit 2 cards ( Next and DWL 520 ) , if i the link was no good , will trie whit flats panel , or in the worst case i will use a bridge whit and external antenna.
Thanks for everyone
With d-link cards, I have had …well… let’s say various results.
Some of them died, some are performing very well. In both 2.4 and 5 ghz.
It seems that 5 ghz it’s a sensible subject on d-link cards. They just act strangely.
