Hello, I have a Mikrotik RB2011UiAS-RM, I configured 3 VLAN’s, my devices get IP addresses from my router, but cannot access Internet.
I can ping everything from the router (so the WAN is configured correctly, I removed the IP addreses form my config), so the problem is somewhere in the middle.
This is the config:
# jan/03/1970 03:17:38 by RouterOS 6.33.2
# software id = LJ3A-ZG8X
add name=Bridge
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/ip neighbor discovery
set ether1 discover=no
set ether2 discover=no
set ether3 discover=no
set ether4 discover=no
set ether5 discover=no
set ether6 discover=no
set ether7 discover=no
set ether8 discover=no
set ether9 discover=no
set ether10 discover=no
set sfp1 discover=no
set Bridge discover=no
/interface vlan
add interface=Bridge l2mtu=1594 name="VLAN - 50 (VOIP)" vlan-id=50
add interface=Bridge l2mtu=1594 name="VLAN - 100 (LAN)" vlan-id=100
add interface=Bridge l2mtu=1594 name="VLAN - 200 (WIFI)" vlan-id=200
set "VLAN - 50 (VOIP)" discover=no
set "VLAN - 100 (LAN)" discover=no
set "VLAN - 200 (WIFI)" discover=no
add name="LAN DHCP" ranges=192.168.100.11-192.168.100.35
add name="VOIP DHCP" ranges=192.168.50.1-192.168.50.25
add name="WiFi DHCP" ranges=192.168.200.1-192.168.200.25
add address-pool="LAN DHCP" disabled=no interface="VLAN - 100 (LAN)" \
lease-time=3d name="LAN DHCP"
add address-pool="VOIP DHCP" disabled=no interface="VLAN - 50 (VOIP)" \
lease-time=3d name="VOIP DHCP"
add address-pool="WiFi DHCP" disabled=no interface="VLAN - 200 (WIFI)" \
lease-time=1h name="WiFi DHCP"
add bridge=Bridge interface=ether2
add address=192.168.100.254/24 comment=LAN interface="VLAN - 100 (LAN)" \
network=192.168.100.0
add address=192.168.50.254/24 comment=VOIP interface="VLAN - 50 (VOIP)" \
network=192.168.50.0
add address=192.168.200.254/24 comment=WiFi interface="VLAN - 200 (WIFI)" \
network=192.168.200.0
add address=192.168.50.0/24 comment=VOIP dns-server=192.168.50.254 gateway=\
192.168.50.254
add address=192.168.100.0/24 comment=LAN dns-server=192.168.100.254 gateway=\
192.168.100.254
add address=192.168.200.0/24 comment=WiFi dns-server=192.168.200.254 gateway=\
192.168.200.254
/ip firewall address-list
add address=192.168.100.0/24 list="Local LAN"
add address=192.168.50.0/24 list=VOIP
add address=192.168.200.0/24 list=WiFi
add action=drop chain=forward comment="Drop Traffic from VOIP to LAN" \
dst-address=192.168.100.0/24 src-address=192.168.50.0/24
add action=drop chain=forward comment="Drop Traffic from LAN to VOIP" \
dst-address=192.168.50.0/24 src-address=192.168.100.0/24
add action=drop chain=forward comment="Drop Traffic from WiFi to LAN" \
dst-address=192.168.100.0/24 src-address=192.168.200.0/24
add action=drop chain=forward comment="Drop Traffic from LAN to WiFi" \
dst-address=192.168.200.0/24 src-address=192.168.100.0/24
add action=drop chain=forward comment="Drop Traffic from VOIP to WiFi" \
dst-address=192.168.200.0/24 src-address=192.168.50.0/24
add action=drop chain=forward comment="Drop Traffic from WiFi to VOIP" \
dst-address=192.168.50.0/24 src-address=192.168.200.0/24
add chain=input comment="Allow access to router from LAN using address list" \
src-address-list="Local LAN"
add action=drop chain=forward comment="Drop invalid connections" \
connection-state=invalid
add chain=forward comment="Allow connections from LAN" connection-state=new \
in-interface=Bridge
add chain=forward comment="Allow established connections" connection-state=\
established
add chain=forward comment="Allow related connections" connection-state=\
related
"Drop all other traffic trough the router"
add chain=input comment="Allow established connections to the router" \
connection-state=established
add chain=input comment="Allow related connections to the router" \
connection-state=related
add action=drop chain=input comment="Drop All other traffic to the router"
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd pin
set pin-number=1557
/system clock
set time-zone-name=Europe/Riga
/system ntp client
set enabled=yes primary-ntp=89.111.54.85 secondary-ntp=89.111.15.218
/system routerboard settings
set protected-routerboot=disabled
/tool bandwidth-server
set enabled=no
Any suggestions where the problem might be?
Thanks in advance
