Clients get IP from WAN DHCP server side
I have setup a new hAP ac2 router in my office. Everything works fine, including OpenVPN, but DHCP clients, sometimes, get IP not from my router but from a DHCP located in the WAN server.
The basic parameters of my router are:
LAN IP ADDRESS: 192.168.1.1/24
WAN IP ADDRESS: 10.59.0.46/24
DHCP RANGE IP: 192.168.1.200-254
How can I avoid clients get IP from an external DHCP?
By properly configuring your hAP ac2. Since you didn’t post configuration, we can’t say what’s wrong. So execute /export hide-sensitive file=anynameyouwish from terminal window, fetch the name and post the contents here (inside [__code] [/code] block).
mkx awarded level 1 of MTUNA certification!
I’m glad our one and only MTUNA instructor (and guru) approves :wink:
Sorry mkx. Here is the config:
# nov/27/2020 16:00:08 by RouterOS 6.44.5
# software id = YH18-J680
# model = RBD52G-5HacD2HnD
# serial number = CB380BEA31D6
add admin-mac=C4:AD:34:C4:58:B4 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] arp=proxy-arp
set [ find default-name=ether3 ] arp=proxy-arp
set [ find default-name=ether4 ] arp=proxy-arp
set [ find default-name=ether5 ] arp=proxy-arp
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=3 arp=proxy-arp band=2ghz-b/g/n \
    channel-width=20/40mhz-XX country=spain disabled=no distance=indoors \
    frequency=auto frequency-mode=regulatory-domain installation=indoor mode=\
    ap-bridge name=Elfos+_2G ssid=Elfos+_2G wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=3 arp=proxy-arp band=5ghz-a/n/ac \
    channel-width=20/40/80mhz-XXXX country=spain disabled=no distance=indoors \
    ap-bridge name=Elfos+_5G ssid=Elfos+_5G wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.1.10-192.168.1.49
add name=vpn_pool ranges=192.168.89.2-192.168.89.10
add name=dhcp_pool2 ranges=192.168.1.200-192.168.1.254
add address-pool=dhcp_pool2 disabled=no interface=bridge name=dhcp1
/ppp profile
set *FFFFFFFE change-tcp-mss=default local-address=192.168.89.1 \
    remote-address=vpn_pool
add bridge=bridge comment=defconf interface=Elfos+_2G
add bridge=bridge comment=defconf interface=Elfos+_5G
/interface l2tp-server server
set use-ipsec=yes
/interface ovpn-server server
set auth=sha1 certificate=SERVER cipher=aes256 enabled=yes \
    require-client-certificate=yes
/interface sstp-server server
set default-profile=default-encryption
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
add address=10.59.0.46/24 interface=ether1 network=10.59.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=192.168.1.0/24 comment=defconf dns-server=8.8.8.8 gateway=\
    192.168.1.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.1.1 name=router.lan
add action=accept chain=input comment="allow OpenVPN" dst-port=1194 protocol=\
    tcp
    established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.89.0/24
add distance=1 gateway=10.59.0.254
/ppp secret
add name=mia profile=default-encryption service=ovpn
add name=anna profile=default-encryption service=ovpn
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=Elfos
/tool mac-server
/tool mac-server mac-winbox
Any particular reason for all bridge interfaces having proxy-arp set?
Why do you have both static IP address set and DHCP client running on ether1 interface?
Thanks mkx, I have no idea why ehternet interfaces had arp-proxy enabled, but after changing ARP option to just “enabled”, it worked as expected.
I have also disabled DHCP client on ehter1 interface.
Thank you very very much
I’m sorry, but I have realised that wireless clients keep getting IP from outer DHCP server.
Both Wireless and Ehternet interfaces have the ARP setting to Enabled.
# nov/30/2020 09:50:31 by RouterOS 6.44.5
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=3 band=2ghz-b/g/n channel-width=\
    20/40mhz-XX country=spain disabled=no distance=indoors frequency=auto \
    frequency-mode=regulatory-domain installation=indoor mode=ap-bridge name=\
set [ find default-name=wlan2 ] antenna-gain=3 band=5ghz-a/n/ac \
/ip hotspot profile
/ppp profile
set use-ipsec=yes
    192.168.1.0
/ip cloud
/ip dns static
    tcp
    protocol=udp
    invalid
    192.168.89.0/24
/ppp secret
/system clock
/system identity
set name=Elfos
/tool mac-server
I’ve no idea why wireless clients would behave differently than wired clients in this aspect. You may want to perform a good cold boot of router to make sure everything is set according to setup …
