I have set up a rb532 with r52h in AP bridge mode, and created a bridge between the card and the lan.
In our lab we have a 20Mb down /15Mb up fibre internet connection.
When I connect with my laptop using intel 3945 or with a proxim card and do a “spedometer” test, I get 2Mbit down, and 15Mbit up.
I have tried with 2 different RB532, and 2 different r52h. I have also tried it with the brand new RB600. This gives the same result.
I am using a 18dbi antenna.
There are no queues, encryption, or access lists. rb532 runs on 2.9.50, rb600 on 3rc10
I was fearing geting a lame answer like this when I said I was using a 18dbi antenna
I have already tried to set the power down to 3db, and I have tried from a good distance from the AP.
The problem is still the same.
I have some more to add. If I run btest from my computer to the ap, I get good speed both ways >20Mbit. This Utilizes the wlan and the bridge interface.
You where right. I turned the TX power down to 2db, and got much more speed.
How do I set the optimal tx power on our systems. We are using 15dBi omni antennas on r52h cards.
