Clients on wifi breaks down internet on PC in LAN
we are using rb133 with RouterOS 5 . But we have trouble with LAN network.
We have this config:
rb133 - 1. interface wan port … 3. interface lan port to hw switch(5 lan PCs), bridged with wireless… DHCP server on this bridge. All is OK, but when the specific clients connect/disconnect from WIFI, it breaks down internet connection on one another PC. It happens only on this PC, without mikrotik router it works fine.
Which topics should I log to find the problem? What should I try block in firewall?
Thanks you for help.
Jakub.
whole day for “00:1E:65:69:9E:F8@wlan_private”
08:36:59 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
...... same
18:10:46 wireless,info 00:1E:65:69:9E:F8@wlan_private: reassociating
18:10:46 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, ok
18:10:46 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
18:10:47 wireless,info 00:1E:65:69:9E:F8@wlan_private: reassociating
18:10:47 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, ok
18:10:47 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
18:10:50 wireless,info 00:1E:65:69:9E:F8@wlan_private: reassociating
18:10:50 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, ok
18:10:50 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
18:17:34 wireless,info 00:1E:65:69:9E:F8@wlan_private: reassociating
18:17:34 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, ok
18:17:34 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
18:17:36 wireless,info 00:1E:65:69:9E:F8@wlan_private: reassociating
18:17:36 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, ok
18:17:36 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
18:24:15 wireless,info 00:1E:65:69:9E:F8@wlan_private: reassociating
18:24:15 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, ok
18:24:15 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
18:24:19 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, extensive data loss
wireless disconnecting(shut down PC breaks down internet connection on LAN pc)
whole day for “00:1E:65:69:9E:F8@wlan_private”, we have virtual public wifi
feb/28 08:37:12 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
feb/28 19:30:52 wireless,info 20:54:76:62:08:DE@wlan_public: connected
feb/28 19:30:57 dhcp,info dhcp_public deassigned 192.168.3.205 from 20:54:76:62:08:DE
feb/28 19:30:57 dhcp,info dhcp_public assigned 192.168.3.205 to 20:54:76:62:08:DE
feb/28 19:36:47 wireless,info 20:54:76:62:08:DE@wlan_public: reassociating
feb/28 19:36:47 wireless,info 20:54:76:62:08:DE@wlan_public: disconnected, ok
feb/28 19:36:47 wireless,info 20:54:76:62:08:DE@wlan_public: connected
feb/28 19:36:49 dhcp,info dhcp_public deassigned 192.168.3.205 from 20:54:76:62:08:DE
feb/28 19:36:55 dhcp,info dhcp_public assigned 192.168.3.205 to 20:54:76:62:08:DE
feb/28 19:37:20 wireless,info 20:54:76:62:08:DE@wlan_public: reassociating
feb/28 19:37:20 wireless,info 20:54:76:62:08:DE@wlan_public: disconnected, ok
feb/28 19:37:20 wireless,info 20:54:76:62:08:DE@wlan_public: connected
feb/28 19:37:21 dhcp,info dhcp_public deassigned 192.168.3.205 from 20:54:76:62:08:DE
feb/28 19:37:21 dhcp,info dhcp_public assigned 192.168.3.205 to 20:54:76:62:08:DE
feb/28 19:41:54 wireless,info 20:54:76:62:08:DE@wlan_public: reassociating
feb/28 19:41:54 wireless,info 20:54:76:62:08:DE@wlan_public: disconnected, ok
feb/28 19:41:54 wireless,info 20:54:76:62:08:DE@wlan_public: connected
feb/28 19:41:55 dhcp,info dhcp_public deassigned 192.168.3.205 from 20:54:76:62:08:DE
feb/28 19:41:55 dhcp,info dhcp_public assigned 192.168.3.205 to 20:54:76:62:08:DE
feb/28 19:44:26 wireless,info 20:54:76:62:08:DE@wlan_public: reassociating
feb/28 19:44:26 wireless,info 20:54:76:62:08:DE@wlan_public: disconnected, ok
feb/28 19:44:26 wireless,info 20:54:76:62:08:DE@wlan_public: connected
feb/28 19:44:26 dhcp,info dhcp_public deassigned 192.168.3.205 from 20:54:76:62:08:DE
feb/28 19:44:26 dhcp,info dhcp_public assigned 192.168.3.205 to 20:54:76:62:08:DE
feb/28 19:55:17 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, group key exchange timeout
feb/28 19:55:17 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
feb/28 19:55:22 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, unicast key exchange timeout
feb/28 19:55:22 wireless,info 00:1E:65:69:9E:F8@wlan_private: connected
feb/28 19:55:27 wireless,info 00:1E:65:69:9E:F8@wlan_private: disconnected, unicast key exchange timeout
feb/28 19:59:00 wireless,info 20:54:76:62:08:DE@wlan_public: disconnected, extensive data loss
some help please.
bump please help.
I replaced mikrotik router for another mikrotik, now setup is Mikrotik->eth2->switch->(PC with internet problem, Radio stream stop playing) … Mikrotik->eth3->(TP link router with another subnet) ->wifi-> Samsung mobile…
If I connect with mobile or some laptops to wifi TP Link, the Radio stream stop playing.
I dont have any clue what to do to solve problem.
