Clients signal strenght/ccq into remote linux SQL server?
Is there a simple solution to export data from registration table into remote linux sql server from MT device od DUDE for customers to access their signal strenght/quality database ??
This is usable for users can check if their signal level is good or bad with one click on website.
Is there non API solution?
Hi there
For NON-API solution i think you can locally save registration table and fetch it from Router using SCP/FTP to a server and parse it to put into database.
Saving file:
[admin@Technologic] /interface wireless registration-table> print stats file=stats
File content:
# jan/ 3/1970  2:48:48 by RouterOS 4.16
# software id = E45Y-YZMH
 0 interface=wlan2 mac-address=00:27:13:7D:F5:B4 ap=no wds=no rx-rate="1Mbps"
   tx-rate="2Mbps" packets=16,12 bytes=4136,4104 frames=16,12
   frame-bytes=4064,4032 hw-frames=16,54 hw-frame-bytes=4448,5328
   tx-frames-timed-out=0 uptime=13s last-activity=480ms
   signal-strength=-60dBm@1Mbps signal-to-noise=38dB
   strength-at-rates=-60dBm@1Mbps 480ms tx-ccq=40% p-throughput=1759
   ack-timeout=30 802.1x-port-enabled=yes wmm-enabled=no
IMHO API would be better for this task becouse you dont need to do on router locally at all and all logic is in server scripts.
I found some php scripts that do exactly what you said…
One php script logs to MT over ftp and downloading…
Other php parsing data into sql.
I have more than 20MT devices with different ROS and parsing is not the same … :slight_smile:
Second problem is in 2.9.xx versions you cannot see ccq in registration table…
PHP that I have, calculate ccq over signal strenght but i think this is not accurate.
