Clinets gets DHCP leases from another DHCP
I have a simple network as in the picture I attach. My issue is that some clients on RB2011(on bridge interface) gets ip from the dhcp server that runs on the HEX and vice versa!
As you can see on the diagram those two routers are connected directly (port10 rb2011 ↔ port3 hex) and the 2 dchp’s servers are running on different interfaces on each router!
if you need any of my conf please ask
You need to post your config on both your router.
Id there are no VLAN everything will float around.
I do suggest you are using VLAN and only one device as DHCP server for all your net.
I’ll post the config later but why do I need to use vlan’s? My Lan’s are completely isolated from each other, since I use different Lan for the interrconnection of the routers and different Lan’s (and ports of course) for the clients Lan’s. Besides this is one of the principal job of a router: to distinguish Lan’s.
DHCP broadcast message (for request) should have stayed in the Lan,right?
But with the wrong config, everything are bridged together in on big net.
Here is the HEX config
add name=dhcp_pool0 ranges=192.168.110.2-192.168.110.254
add address-pool=dhcp_pool0 disabled=no interface=ether2 lease-time=3h name=dhcp1
/interface detect-internet
set detect-interface-list=all
add address=10.5.10.2/29 interface=ether1 network=10.5.10.0
add address=192.168.110.1/24 interface=ether2 network=192.168.110.0
add address=10.5.10.9/29 interface=ether3 network=10.5.10.8
/ip dhcp-server alert
add disabled=no interface=ether2
add disabled=no interface=ether1
add disabled=no interface=ether3
add address=192.168.110.0/24 dns-server=8.8.8.8 gateway=192.168.110.1
set servers=8.8.8.8,8.8.4.4
add action=dst-nat chain=dstnat dst-port=41103 in-interface=ether1 protocol=tcp to-addresses=10.5.10.10 to-ports=8291
add action=dst-nat chain=dstnat dst-port=41104 in-interface=ether1 protocol=tcp to-addresses=10.5.10.11 to-ports=8291
add action=dst-nat chain=dstnat dst-port=41105 in-interface=ether1 protocol=tcp to-addresses=10.5.10.12 to-ports=8291
add check-gateway=ping distance=1 gateway=10.5.10.1
add check-gateway=ping distance=1 dst-address=192.168.1.0/24 gateway=10.5.10.10
I get alerts that a dhcp exists in interface 2 and this dhcp has the mac of rb2011!!!
and here is the RB2011
add name=bridge1
set [ find default-name=ether10 ] loop-protect=on
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=2437 mode=ap-bridge ssid=XXXXXXXX
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.50
add address-pool=dhcp_pool0 disabled=no interface=bridge1 lease-time=15h10m name=dhcp1
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=wlan1
add address=10.5.10.10/29 interface=ether10 network=10.5.10.8
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.1
set servers=8.8.8.8
add action=masquerade chain=srcnat disabled=yes out-interface=ether10
add check-gateway=ping distance=1 gateway=10.5.10.9
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
Thnks for the help
