Clock problem on RB150 with ntp client enabled
Hi all.
I have a problem with my rb150. It doesn’t have battery and lose time on reboot, so I should use ntp client. I’ve setup the client and recieving updates but my clock is one hour behind. I’ve set DST +1 hour but it only applyied when I hit Apply button on Winbox interface. Then clock shows correct time. But when I reboot I am having to press Apply again, DST not active despite of correct setting in Manual Time Zone.What does this Apply button do? May be it’s possible to set it by script?
My OS version is 3.7
Thank you for the report.
We are aware of this problem for DST, it will be fixed in the upcoming versions.
Thank you. Looking forward for new version.
I think that issue with NTP client should be fixed now.
Yes, thank you. I’ve upgradet to 3.9 and now it working fine.
Hi all.
I have the same problem with my rb150 (also reproduce it on RB333).
It loses time on reboot even If my ntp if configured properly. I have to wait abot 3-5 min after reboot until the clock is corect again. Is there a way to save the date/time on reboot because I have an incosistency in my logs every time a router is rebooted because of time reset.
My OS version is 3.10
There is no way to save clock during reboot [because RB150 does not have internal memory/battery].
