Clocked Connection Error with MS Outlook
i have an problem with Outlook, so i want to know is the probblem the setting from my network infrastructur
every time when i connect with wifi outlook says the connection is clocked and it will worke offline so i had to activate the connection manual
Configurations
first basestation with wifi off
second ap for wifi
i cant build to code boxes so both configurations in the box
maby somebody can help
Update i have solved the Problem it was an checkbox from windows that identify the wifi as clocked connection, when i uncheck it it works normal
best regards
