Hi
I can connect to routerOS api via pear2
$client = new RouterOS\Client(‘host’, ‘user’, ‘pass’, ‘port’);
What is command for close connection now?
Api user in users table still logged in?
Hi
Simply unsetting the $client variable with unset(), or eliminating it from any scope* should disconnect. It should even implicitly send a “/quit” command, as some older RouterOS versions and some RouterBoards are known to otherwise keep the connection hanging.
The destructor should also be called at the end of the PHP script though. If your script is over, and the connection is still hanging, there’s something else going on. So far, I know of only 2 cases where this can happen:
Thank you for using PEAR2_Net_RouterOS.
Thank you for your reply.
This is my api commands:
<?php use PEAR2\Net\RouterOS; require_once 'PEAR2_Net_RouterOS-1.0.0b4.phar'; $username = strtolower($rw['pay_from']); if ($rw['memo'] == "یک ماه 128 کیلوبیت نامحدود") {$addcredit = "30d"; $groupname = "128";} else if ($rw['memo'] == "یک ماه 256 کیلوبیت نامحدود") {$addcredit = "30d"; $groupname = "256";} else if ($rw['memo'] == "یک ماه 512 کیلوبیت نامحدود") {$addcredit = "30d"; $groupname = "512";} else if ($rw['memo'] == "یک ماه 1 مگابیت نامحدود") {$addcredit = "30d"; $groupname = "1024";} else if ($rw['memo'] == "یک ماه 2 مگابیت نامحدود") {$addcredit = "30d"; $groupname = "2048";} else if ($rw['memo'] == "یک ماه 3 مگابیت نامحدود") {$addcredit = "30d"; $groupname = "3072";} else if ($rw['memo'] == "سه ماه 128 کیلوبیت نامحدود") {$addcredit = "90d"; $groupname = "128";} else if ($rw['memo'] == "سه ماه 256 کیلوبیت نامحدود") {$addcredit = "90d"; $groupname = "256";} else if ($rw['memo'] == "سه ماه 512 کیلوبیت نامحدود") {$addcredit = "90d"; $groupname = "512";} else if ($rw['memo'] == "سه ماه 1 مگابیت نامحدود") {$addcredit = "90d"; $groupname = "1024";} else if ($rw['memo'] == "سه ماه 2 مگابیت نامحدود") {$addcredit = "90d"; $groupname = "2048";} else if ($rw['memo'] == "سه ماه 3 مگابیت نامحدود") {$addcredit = "90d"; $groupname = "3072";} else if ($rw['memo'] == "شش ماه 128 کیلوبیت نامحدود") {$addcredit = "180d"; $groupname = "128";} else if ($rw['memo'] == "شش ماه 256 کیلوبیت نامحدود") {$addcredit = "180d"; $groupname = "256";} else if ($rw['memo'] == "شش ماه 512 کیلوبیت نامحدود") {$addcredit = "180d"; $groupname = "512";} else if ($rw['memo'] == "شش ماه 1 مگابیت نامحدود") {$addcredit = "180d"; $groupname = "1024";} else if ($rw['memo'] == "شش ماه 2 مگابیت نامحدود") {$addcredit = "180d"; $groupname = "2048";} else if ($rw['memo'] == "شش ماه 3 مگابیت نامحدود") {$addcredit = "180d"; $groupname = "3072";} else if ($rw['memo'] == "یکسال 128 کیلوبیت نامحدود") {$addcredit = "365d"; $groupname = "128";} else if ($rw['memo'] == "یکسال 256 کیلوبیت نامحدود") {$addcredit = "365d"; $groupname = "256";} else if ($rw['memo'] == "یکسال 512 کیلوبیت نامحدود") {$addcredit = "365d"; $groupname = "512";} else if ($rw['memo'] == "یکسال 1 مگابیت نامحدود") {$addcredit = "365d"; $groupname = "1024";} else if ($rw['memo'] == "یکسال 2 مگابیت نامحدود") {$addcredit = "365d"; $groupname = "2048";} else if ($rw['memo'] == "یکسال 3 مگابیت نامحدود") {$addcredit = "365d"; $groupname = "3072";} else if ($rw['memo'] == "یکسال + 2 ماه رایگان 128 کیلوبیت نامحدود") {$addcredit = "420d"; $groupname = "128";} else if ($rw['memo'] == "یکسال + 2 ماه رایگان 256 کیلوبیت نامحدود") {$addcredit = "420d"; $groupname = "256";} else if ($rw['memo'] == "یکسال + 2 ماه رایگان 512 کیلوبیت نامحدود") {$addcredit = "420d"; $groupname = "512";} else if ($rw['memo'] == "یکسال + 2 ماه رایگان 1 مگابیت نامحدود") {$addcredit = "420d"; $groupname = "1024";} else if ($rw['memo'] == "یکسال + 2 ماه رایگان 2 مگابیت نامحدود") {$addcredit = "420d"; $groupname = "2048";} else if ($rw['memo'] == "یکسال + 2 ماه رایگان 3 مگابیت نامحدود") {$addcredit = "420d"; $groupname = "3072";} $client = new RouterOS\Client('***', '***', '***', '***'); $setRequest = new RouterOS\Request('/tool user-manager user set'); $client($setRequest ->setArgument('numbers', $username) ->setArgument('add-credit', $addcredit) ->setArgument('group-name', $groupname) ); ?>And this is active users:
0 apr/05/2014 11:20:59 admin *** api
1 apr/05/2014 15:04:14 admin *** api
2 apr/05/2014 18:18:47 admin *** api
Please post that command for closing sessions.
Thank you
Before the “?>”:
unset($client);
That is all.
Note that this will not close your existing connections. It will only make sure new connections don’t stick around. Sadly, the only way to clear up old connections is to reboot your router, since your web server has already closed the connection, and can’t somehow “resume” it.
This code not worked
unset($client);
The session still logged in..
Like I said - this will NOT close your existing connections.
You must reboot the router to clear those.
I know.
It means new api connection not removed with this code.
The new connection added to user active list.
# WHEN NAME VIA
0 apr/05/2014 11:21:00 admin api
1 apr/05/2014 15:04:14 admin api
2 apr/05/2014 18:18:47 admin api
3 apr/06/2014 16:27:25 admin api
5 apr/06/2014 16:29:56 admin api
6 apr/06/2014 16:31:34 admin api
New sessions are not removed? That’s odd…
Try to explicitly send a “/quit” command at the end, i.e.
$client($setRequest
$client(new RouterOS\Request('/quit'));
Also, please check if there’s anything in PHP’s error logs. It should go without saying that you should enable error logging if you haven’t.
Still not working.
Winbox log only say:
user admin logged in from *** via api
What RouterOS version are you using? PHP version?
(I’ll have to try and duplicate this, as with my setup, I don’t seem to be able to…)
RouterOS 4.17
PHP Version 5.3.28
Yep… It’s a RouterOS bug. I can duplicate it with a VM.
I can’t think of any solution here though… Other than to upgrade at least to 5.. The 4. series is already not supported by MikroTik.
