Close down DNS requests
Hi guys,
I am seeing these DNS enteries
They have extraordinarily long TTL (24Hrs at beginning).
I googled them and found this website link.
http://dnsamplificationattacks.blogspot.co.uk/2013/10/domain-krastius.html
It states that I am likely either taking part in a DNS amplification attack or I am being DDOSed.
I have these rules in place to protect my WAN connections
 /ip firewall filter> print
 0   chain=input action=drop connection-state=new protocol=udp in-interface=ether1 - WAN1 src-port="" dst-port=53
 1   chain=input action=drop connection-state=new protocol=udp in-interface=ether2 - WAN2 src-port="" dst-port=53
 2   chain=input action=drop connection-state=new protocol=tcp in-interface=ether1 - WAN1 src-port="" dst-port=53
 3   chain=input action=drop connection-state=new protocol=tcp in-interface=ether2 - WAN2 src-port="" dst-port=53
The website informs us that I should use an iptables rule to control this.
Rule 1
iptables --insert INPUT -p udp --dport 53 -m u32 --u32 "0x28&0xFFDFDFDF=0x064b5241 && 0x2c&0xDFDFDFFF=0x53544902 && 0x30&0xDFDFFF00=0x55530000" -j DROP -m comment --comment "DROP DNS Q krasti.us"
Rule 2
iptables --insert INPUT -p udp --dport 53 -m string --from 40 --to 51 --algo bm --hex-string '|066b726173746902757300|' -j DROP -m comment --comment "DROP DNS Q krasti.us"
Can anyone help me configure these rules on my router. Additionally, Can I set a maximum TTL for DNS of say 10mins?
Thanks in advance.
The problem do not come from internet, but from your internal network.
One of your user are infected.
Block all connection from / to this list:
http://www.spamhaus.org/drop/
And check if your client make excessive DNS MX request or excessive SMTP request
Hi.
Look here http://forum.mikrotik.com/t/great-script-automatic-generate-spamers-ip-adress-list/74355/1
What does “/” mean?
If I use the script which the other poster suggested. How do I create a firewall rule that blocks these coming from the LAN?
Thanks.
I ran the code as suggested, but it has not created an Address List under firewall. Any ideas where I am going wrong?
Did you add? :
Schedule the download and application of the openbl list
/system scheduler add comment=“Download openbl list” interval=7d name=“DownloadBegoneList” on-event=Download_openbl start-date=jan/01/1970 start-time=01:05:00
/system scheduler add comment=“Apply openbl List” interval=7d name=“InstallBegoneList” on-event=Replace_openbl start-date=jan/01/1970 start-time=01:15:00
You can try run it manual in system-scheduler. First run “DownloadBegoneList”, and afther 1-2 min. run “InstallBegoneList” Then check Firewall address list.
It didnt create an address list at all…
Am I supposed to manually create an address list? Or should it have been created when running the script?
When I enter the command into terminal
 /system script add name="Download_openbl" source={
{...  /tool fetch url="http://joshaven.com/openbl.rsc" mode=http;
{...  :log info "Downloaded openbl.rsc from Joshaven.com";
I get the message.
“failure: item with such name already exists”
I checked my “Files” folder in winbox but dont see the files already existing…
Help
ok, forgive me guys. I am very new to Mikrotik and learning fast :slight_smile:.
I now have it working correctly.
When creating a firewall rule for this list, I have done as follows.
chain=forward action=drop src-address-list=blacklist
     dst-address-list=blacklist in-interface=all-ethernet
     out-interface=all-ethernet
Does that look correct?
Thanks guys.
add chain=forward action=drop src-address-list=blacklist in-interface=all-ethernet
add chain=forward action=drop dst-address-list=blacklist in-interface=all-ethernet
