closed
Are you using encrypted links? How are they accessing the other hosts via layer 2 broadcast?
Layer 2 Client isolation is the first thing I would look at. What kind of wireless gear are you using to connect them?
Thank you IPANetEngineer for your replying.
no , the links aren’t encrypted because it will slow down the network also Layer 2 isolation isn’t good as it sounds ( Layer 2 isolation is built into an access point to prevent two wireless clients from seeing each other’s shared resources. So if you have a folder set to be shared on your laptop, another person couldn’t connect to your laptop and see/download what’s in that shared folder. )
again thank you for replying .
Well, consider to encrypt, loose SOME performance, and have the funny ppl out of your net.
I use static - aes-ccm, and I cant say that performance is affected. In 2003, maybe. in 2013, with new hardware etc - NO.
and to isolate l2 in mikrotik, fulfil your net with horizon at bridge interfaces.
Thank you samsung172
It seems the only option I got. Any way I was looking for more practical solution.
again thank you.
