Model: RB5009UG+S+IN
Firmware: v7.13.5 Stable
License Level: 5
IP/CLOUD
DDNS ENABLE: yes
UPDATE TIME ENABLE: yes
USE LOCAL ADDRESS: yes
IP/Services
Winbox enabled: yes
Wibox port: 8291
IP/Firewall Filter
Chain: input
Protocol: tcp
Dst port: 8291
Action: Accept
Save
My configuration is not working, what I missed? Please help me.
Do you have a public (and non CGNAT) IP address?
Are you testing from the internal network? Then you might need NAT loopback:
https://help.mikrotik.com/docs/display/ROS/NAT#NAT-HairpinNAT
My advise: configure Wireguard and use that to administrate the router:
https://help.mikrotik.com/docs/display/ROS/Back+To+Home
It is not clear what you want, and unlike Erlinden I don’t see any point on running around like a chicken with its head cut off.
Please clearly state what requirement or requirements you are attempting to communicate. ( describe the traffic flow required in terms of users, use a diagram if necessary ).
do you need access your mikrotik outside your home ?
isp on my home didn’t give ip public (shared ip public), so i cannot use ddns / ip cloud
therefore, i’m using zerotier
Thank you for the advice Erlinder
@kangarie yes I wnat to access my mikrotik router outside home. Can you give me a link about zerotier how to configure it?
You are welcome! And please read the link I posted about Wireguard. Then you won’t have to do anything (a bit more) complicated (like Zerotier).
