i need a free Cloud based Mikrotik routerboards management system. Can you suggest me some ?
Hey,
Despite of this what can be found on Github you can use e.g DUDE Server placed on CHR on e.g some VPS.
CHR would need to have VPNs to all monitored nodes but if your whole environment is ROS based it will do a lot things for you.
I think this is the lowest cost option possible.
Greg
My router does not support Dute (RB2011). is there any other way?
You asked for a “cloud-based” management system (e.g., Dude). Responder suggested running Dude on a VPS in the Cloud. He did not suggest running it on your hardware, which is not cloud-based in the first place.
