CLOUD CORE ROUTER
https://www.youtube.com/watch?v=EL6IxslKiHs
Email your distributor
Finally :wink:
Reserved 6 from the first batch to my country. Taking the day
off to meet the trailer when it arrives in about two weeks.
Childish I know, but we are taking about the router of the year :wink:
Yay!
So, what is this CCR1016 model number I see silk-screened onto the board?
16 core version?
–Eric
CCR1036-12G-BU - $625.00
CCR1036-12G - $645.00
CCR1036-12G-4S - $995.00
Looks like product naming gives lots of specs:
CCR10-G-S
- number of cores
- number of Gigabit Ethernets
- number of SFP cages
-BU -board unit (without Rackmount case), for installations in your own boxes :slight_smile:
OK to clear up some rumours:
CCR1036-12G-4S
Cloud Core Router 1036 with Tilera 1.2Ghz 36-core CPU, 4GB RAM (2x2GB), 4xSFP, 12xGbit Ethernet, RouterOS L6, 1U rackmount case with touchscreen LCD, power supply
List price $995
CCR1016-12G
Cloud Core Router 1016 with Tilera 1.2Ghz 16-core CPU, 2GB RAM (2x1GB), 12xGbit Ethernet, RouterOS L6, 1U rackmount case with touchscreen LCD, power supply
List price $645
CCR1016-12G-BU (without enclosure)
Cloud Core Router 1016 with Tilera 1.2Ghz 16-core CPU, 2GB RAM (2x1GB), 12xGbit Ethernet, RouterOS L6, touchscreen LCD, power supply
List price $625
Our tests show that Cloud Core Router series can push wire speed throughput via all ports (up to 16Gbps full duplex on CCR1036-12G-4S, up to 12Gbps on CCR1016-12G), making it the fastest MikroTik product ever made. Pre-production batches for evaluation will arrive from the factory in ~two weeks.
Please download brochures below:
http://www.mikrotik.com/download/share/CCR1036_12G_4S_web.pdf
http://www.mikrotik.com/download/share/CCR1016_12G_web.pdf
What’s going to be so good about the cloud core router anyways? What types of stuff or user interface is there versus the regular mikroitik/winbox? Any demo available for this unit?
Performance! Everything else like regular MikroTik RouterOS v6 router.
Awesome pricing!
Pre production batches in 2 weeks ?
What about the production batches ?
Do these have hardware acceleration for aes IPSec?
Other the that, as said before, great pricing guys!
Ill take 2
9, 16, 36:
http://www.tilera.com/sites/default/files/productbriefs/TILE-Gx8009_PB036-02.pdf
64 Core is a different family:
http://www.tilera.com/sites/default/files/productbriefs/PB010_TILE64_Processor_A_v4.pdf
Will there be a version with temperature range -20 to 60 Degree
for outdoor cabinet usage?
Would be great at the base of towers.
The board unit with 16 cores will happily run at those temperatures if installed in a waterproof case.
Can you tell me the aes128 performance of the ccr models? Do they have also a special crypto chip?
THX
Normis: Can you tell us power consumption?
Same here, Basically need a version of the RB450G with this chip TILE-Gx8009 (with the encryption option) PN# TLR4-00980CG-12CE
No need for a silly colour touch screen on a commercial router. Only adds to the cost and wank factor.
On the full spec version SFP+ would make more sence
normis, CCR support 8/16GB ram. Only CCR or x86 ros v6 too?
I think only CCR, because have 64bit V6. x86 dont have this feature
