Cloud Core Touchscreen Axis [SOLVED]
Just received my CCR1016-12G, started to play with it but the touchscreen on my model got the wrong axis. I have to move the finger from the left to the right to scroll down, or touch the left/right of the screen to “click” the top/bottom of the screen.
If I try to recalibrate using winbox I got a “Calibration failed. Try again!”
how about upgrading/downgrading ros?
I confirm that upgrade to rc11 fixed the problem
I can also recommend a “/lcd recalibrate” process.
I tried to recalibrate few times after upgrading, i still have the same error message: “Calibration failed. Try again!”.
I did not mention that because it works enough for me.
When calibrating, use something sharp, like a pencil. Then calibration is more accurate and will not fail so easily.
