cloud dns problem
Hello.
I have a problem, I can’t figure out how to solve it.
CLOUD DNS is not working. the field where the public address should be specified is empty, DNS NAME is empty. The device is RB2011.
Help me understand what the problem is and fix it.
[admin@*] > /system routerboard print
       routerboard: yes
             model: 2011UiAS-2HnD
     serial-number: 4E*********5
     firmware-type: ar9344
  factory-firmware: 3.14
  current-firmware: 6.48.6
  upgrade-firmware: 6.48.6
[admin@*] > /ip cloud
advanced  edit  export  force-update  get  print  set
[admin@*] > /ip cloud print
          ddns-enabled: yes
  ddns-update-interval: 1m
           update-time: no
                status: updating...
Hi, I’m having the exact same problem with my RB1100. It’s updated to the latest version (7.19.1).
Have you managed to fix it or does anyone know how?
