Cloud Hosted Router
Anyone else with network problems on Hyper-V? I can’t communicate with the router (ping, mac ping, winbox)
IP is manually assigned. Hyper-V guest is 1 generation with legacy network adapter.
I am in disbelief, my emails to your sales department didn’t fall on deaf ears after all :wink:
This is a definite move in the right direction. Great work Mikrotik!
Hopefully this is licensed per RouterOS VM, per month. This will make it easy for cloud providers to spool up Routers for new clients without having to worry about committing to an entire years licence fee. It will also make it easy for short term contracts where you just need a router for 3 months, or for Proof of Concepts. And it will deliver a recurring revenue stream to Mikrotik to pay for new features !
I have been hosting cloud hosted ROS since 2010. Paid for the licenses L4&L5 but, is it possible to upgrade to CHR?
Currently we only offer the 1Mbit limited version, if you don’t need higher sped, just use this image. In future we will offer subscriptions, but I don’t think there will be any migration between old license and new.
Will Hyper-V be properly supported? Both Client and Server versions would be handy…
is possible to install user-manager package?
It’s a RouterOS device, just virtual. Install any package you want
Will there be a one time purchase option or will this just be a subscription based model ?
Yey for custom drivers though :slight_smile:
We are planning a one time payment option as well.
Such good news this!!!
VirtIO drivers (http://wiki.libvirt.org/page/Virtio) not supported? big omission.
Like I already said, VIRTIO is coming
VirtIO disk driver absent, but VirtIO network driver works at first sight.
bravo! very comfortable in this environment to do the lab\test network.
Great!
Perfect!!!
This is great! Nice idea!
When I try to upgrade to most recent version (6.30.2) it resets the free license to a 24 hours license. Here are some screenshots.
Are we going to be able to upgrade this RouterOS VMs?
Before:
After:
Best regards.
Apparently v6.30.2 does not have the new code to support the new licensing for the CHR.
I believe upgrades will work just fine after 6.31 is released.
6.30.x is older than 6.31
6.30.x only includes fixes, not new features, such as this
I try to upgrade to 6.31.rc10 and error was: license does not permit to upgrade routeros.x86-6.31.rc10
I was upgrading via system/packages/upgrade
Hello Normis,
You are right. I choose current version from the upgrade menu.
However, if you try to upgrade to the release candidate, then the actual license won’t let you.
Best regards.
