Derek
1
I’m using a RB5009, and want to use cloud as my ddns, after trying to enable the cloud, i get this in cloud status,
> /ip cloud print
ddns-enabled: yes
ddns-update-interval: none
update-time: no
dns-name: ***.sn.mynetname.net
status: updating...
back-to-home-vpn: revoked-and-disabled
I’m comfirm My router time is correctly using ntp, didn’t work.
try to enable and disable static domain cloud2.mikrotik.com and cloud.mikrotik.com but still didn’t work.
allow firewall on udp 15252, 53 and 123 to enable the router can received data, but still didn’t work.
does anyone know what am I config wrong, hoping to get answer.
Thank you.
Derek
3
sorry for the long reply, I’m trying the other approach for DDNS(fetch to no-ip),
but still not work, but that another story.
For Cloud DDNS update,
I did able to ping cloud2.mikrotik.com and get the ip
what should I do next?
allow firewall on udp 15252, 53 and 123 to enable the router can received data, but still didn't work.
Does this mean your DNS server is publically available? That could explain the high rtt.
You might want to share your config:
/export file=anynameyoulike
Remove serial and any other private info, post between code tags by using the </> button.
Derek
5
thank you for the help, here are the code
- I find out I’m using static DNS to resolve IP,
- the domian cannot ping after disable static DNS
what should I do to make routerOS able to using DNS server and ping?
# 2025-05-05 00:00:14 by RouterOS 7.18.2
# software id = HKJ2-B1GR
# model = RB5009UG+S+
# serial number = HEH08
add admin-mac= auto-mac=no comment=defconf dhcp-snooping=yes \
name=bridge port-cost-mode=short
/interface wireguard
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.8.10-192.168.8.254
add name=wifi ranges=192.168.20.100-192.168.20.200
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add address-pool=wifi interface=ether8 lease-time=5h name=wifiDHCP
/ip smb users
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10 trusted=yes
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
set discover-interface-list=LAN lldp-med-net-policy-vlan=1
/interface detect-internet
set detect-interface-list=all
add interface=ether8 list=LAN
add interface=vpn list=LAN
/interface ovpn-server server
/interface wireguard peers
add address=192.168.8.1/24 comment=defconf interface=bridge network=192.168.8.0
add address=192.168.20.1/24 interface=ether8 network=192.168.20.0
add address=192.168.11.1/24 interface=vpn network=192.168.11.0
/ip cloud
set ddns-update-interval=5m
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
add address=10.120.8.0/24 comment=defconf dns-server=1.1.1.1,8.8.8.8 gateway=\
10.120.8.1 netmask=24
add address=192.168.20.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.20.1 \
netmask=24
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.8.1 address-list=192.168.8.0/24 comment=defconf name=\
router.lan type=A
add address=192.168.20.1 address-list=192.168.20.0/24 name=wifihost type=A
add address=223.255.185.3 name=stdtime.gov.hk type=A
add address=159.148.172.251 name=cloud2.mikrotik.com type=A
add address=159.148.147.229 name=cloud.mikrotik.com type=A
add address=158.247.7.204 disabled=yes name=dynupdate.no-ip.com type=A
add address=159.148.172.226 name=upgrade.mikrotik.com type=A
/ip firewall address-list
add address=192.168.11.0/24 list=vpn_list
established,related,untracked disabled=yes in-interface-list=WAN protocol=\
icmp
add action=drop chain=forward disabled=yes dst-port=80,22,443,8291 \
in-interface=ether1 protocol=tcp
add action=accept chain=input protocol=udp src-port=53
add action=accept chain=input dst-port=53 protocol=udp
invalid
add action=accept chain=forward disabled=yes in-interface-list=LAN \
out-interface-list=WAN
add action=accept chain=input dst-port=13355 in-interface=ether1 protocol=udp
add action=accept chain=output comment="Allow HTTP traffic" dst-port=80 \
protocol=tcp
add action=drop chain=forward out-interface-list=WAN src-address-list=\
"server"
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall service-port
set sip disabled=yes
/ip ipsec profile
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=LAN
set winbox address=LAN
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set strong-crypto=yes
/ip traffic-flow
set enabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
/snmp
set enabled=yes
/system clock
set time-zone-name=Asia/Hong_Kong
/system logging
add topics=dns
add topics=fetch
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=stdtime.gov.hk
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
here are the dns status on routeros
[admin@MikroTik] /ip/dns> print
servers: 1.1.1.1
8.8.8.8
dynamic-servers:
use-doh-server:
verify-doh-cert: no
doh-max-server-connections: 5
doh-max-concurrent-queries: 50
doh-timeout: 5s
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
max-concurrent-queries: 100
max-concurrent-tcp-sessions: 20
cache-size: 2048KiB
cache-max-ttl: 1w
address-list-extra-time: 0s
vrf: main
mdns-repeat-ifaces:
cache-used: 75KiB
Derek
6
thank you for the help ,
the ip cloud service is not working after I reset the firewall, I think I miss config something
