Cloud Managed Routers
I would like to see a whole swag of new features that would help manage RouterOS devices.. by the thousand. I want to be able to manage Mikrotik HomeAPs from the cloud, regardless of what firewalls, NATed routers etc might be in between.
  1. HTTP POST support for sending usage summaries etc to cloud service. HTTP is good, as it will be open through most firewalls. I can use HTTP GET, but as all the parameters are part of the URL, its easy for some foreign agent to attempt to pollute the data.
  2. RouterOS as a uPnP client. The PHP API is good, but doesn’t help if the RouterOS device to work behind a NATed router. Allow RouterOS device to work behind a NATed router by pushing port forwarding rules to the NATed router.
  3. Mikrotik “PUSH” protocol. Maybe something similar to the Apple Push Protocol that leave a (client initiated) TCP session open, to get notifications/commands back to a firewalled/NATed RouterOS device, without the need to do periodic Polling (Pull) by the RouterOS device.
  4. Easy reporting of user authentication and LAN DHCP lease information over SSL. I can collect and send this using syslog, but its not secure.
  5. Parsing and secure passing of RouterOS WebProxy data to the cloud. Again syslog is possible, but data volume is huge and syslog is insecure. I just want to summaries of Date/Time, LocalIP, Username (matched via DHCP lease to IP), URL, byte count, of the HTTP Request Responses.
  6. Ability to have multiple devices associated with one Hotspot user, some using username for authentication, some using MAC, but all accounting against one usage limit and time limit.
  7. TR-069 - may be a solution for updating some router configs remotely, but probably not a “Cure all”.
I want to support, but I believe that this router is not only for home use but also for corporations.
In this connection I wish to emphasize that the overall configuration should utilika uschestvovat is obloka or any non-corporate centers.
I am an advocate for a unified utility with common configurations for all devices on korporatinom server, and for home cloud.
