I setup load Balance 1 pppoe + 2 wan from dhcp server but I cannot login mikrotik by cloud
help me please
thank you
help me please
thank you
This happens to me also with dual wan 1 pppoe and 1 dhcp. The reason is that cloud ip sometimes takes the ip from pppoe and sometimes from dhcp. From pppoe it works from dhcp no because is behind nat. Try to disable dhcp wans and see that it works right. My sollution was to setup dmz in dhcp router. Also you can change the setup if possible of course from dhcp to pppoe. I hope mikrotik should place an option from which wan (interface) cloup ip updates.
Also when make changes wait a minute to update. I think cloud ip interval is 1 minute. Or click force to update.
Sent from my iPad using Tapatalk
