Cloud Router Issue
Hi
Good day
We have two Mikrotik cloud routers model No.CRS212 and we want to configure loopback on both and then use traffic generator to generate traffic which passes through both and comes back. Please suggest the method.
We configure VLAN and master port in the same router but none of the ports pass full traffic and we have at least 950MB which must be 1G.
Please let us know what the problem/solution can be in two above cases.
Best regards
S.A.Alavian
CRS is a switch, not a router. While it has an embedded router on-board, that router is mainly for management purposes and is relatively weak. You may not be able to generate a full 1G of test traffic using this device.
