Cloud Router Switch QoS priority
Hello all!
I’ve been wondering about the QoS priority values.
Does 1 mean the higher priority or the lower?
1 is the highest.
8 is the lowest.
However you should have queue with at least two different priority settings (to make them work).
There is no difference in priority field, when all queue have priortity=1
Hi sergejs,
in /interface ethernet switch qos-group, priority 1 is highest an 15 is lowest ?
Thank you.
Antonio.
My reply was about /queue priority.
Yes, the same applies for qos-group (1 is highest 15 is lowest), we are working on documentation for new features.
