CRS125-24G-1S-RM
that is the switch I am using, it was working for 3 months, then one day the ISP decided to shut down my clients internet. They said that there was too much traffic coming from his house or something, the client didnt get specific and when i called the ISP I forgot to ask. Anyway, the switch has never worked after that. The Modem works when I plug into it from my laptop, I pinged 8.8.8.8 1000 times and it didnt fail once.
However when I plug the switch into the Modem, the modem sees the switch on port 24, my gateway port, says its connected, however I cannot ping 8.8.8.8 for the life of me! I cannot ping any addresses that the modem is giving my router.
So I brought in a second cloud switch, downloaded my config to it and same thing, it does the exact same thing! I attached the config, I have no clue what is going on and I emailed Mikrotik’s tech support but they wont even respond.
Any ideas?
