Cloud: update time without ddns?
Hello everybody,
with Mikrotik’s cloud service it’s possible to disable dynamic dns update, but enable time update:
/ip cloud set ddns-enabled=no update-time=yes
Not sure if this is a valid configuration, so:
  • Does the device update the time if dynamic dns is disabled?
  • Can I check if time has been updated? (“/ip cloud get status” is not available without ddns)
I would use the latter from a script to check if time can be expected to be correct…
That time should only used for when nothing else is configured, but it’s not very precise. Better just configure NTP client to time.google.com
Yes, I know that. I have configured NTP on all my devices.
Still I have a script that requires the time to be “about right” at least (so cloud is fine) - and this script should work on as many devices as possible with whatever configuration.
I would still appreciate to have detailed information on time update from cloud and its status.
