I am interested in upgrading the RAM in my ccr1016-12g router by Mikrotik. I searched through the website and could find no information regarding RAM Upgrades. Could someone point me in the right direction for instructions and specifications of the RAM that I would need to purchase?
Our EM model uses a tested memory module (at the full temperature range in the datasheet) and not all the modules we tested worked (even though the specs were the same) – so there is some risk. We do have a memory tester that can be left running when you try your new modules – but we also have a temperature chamber test when we confirm that they work.
So basically, it might work, but I recommend using our CCR “EM” offering with the tested modules.
Before the new year, I will be definitely purchasing the CCR1036-12G-4S-EM… Wanted to upgrade my current setup, as I can’t help but having the best at all times. Just got done buying gold plated Cat 6a Ethernet cables
