CloudCore Master / Slave port???
I just purchased a CloudCore CCR-1036 8G2S and I can’t set any master ports on any of the ethernets. Has this feature been disabled from this router? My 1100AHx2 seems to do it just fine. When I try to set the master port in the terminal it says “master port and bandwidth settings not supported on this port”. How do I have a master slave relationship with the ports on this device?
master and slave ports refer to switch chip features
ccr1036 dont have any switching chips, all ports directly from cpu
check block diagram for the model
http://i.mt.lv/routerboard/files/CCR1036-8splus-diagram-140327102650.pdf
Correct, no switch in that unit.
You will want to create a bridge and add the needed ports into the bridge.
Ah my mistake. Thanks for your help guys.
