hello all
is there a need to shield the cm-9 or any radio for that matter in the box that they are housed in.?
if so what is the best shielding material to use. to isolate the radios from each other..
reason i ask is I am doing testing on two radios (cm-9) and i know that is is also true for the old silver cards from lucent or any radio for that matter.
that if two cards are seated next to each other that they in general omit RF and can cause some loss of signal . even if they are on different Freq.
the bleed over occurs . so how can you put 4 or more radios in one enclosure without interference ?/
what is the best recommendation or input ![]()
Randy
