CM9 on RB112
Hi -
I have a RB112 and am trying to use a CM9 wireless card in it.
However, the board does not seem to recognize the card. There is nothing listed on Interface tab for the card.
Can anyone give me some advice on what I am doing wrong? Do I need to load a driver? Other?
Software version 3.2.
Thanks!
Check the PCI tab of System → Resources for the card.
Then make sure Wireless package is enabled on rb112
maybe upgrade to 3.30 but i suspect it might be not showing up due to problems with the board not talking to the radio module.
