Hi again,
Today my Daddy bought me a CNet CWP-854 Wireless PCI Adapter and i istalled it on my MikroTik Router but I cant see it as an interface
do I have to install any drivers, if so pls tell me how?
Pls help ![]()
Hi again,
Pls help ![]()
If you don’t see it, you cannot use it. It’s simple:)
Damn i spent 25€ for it
Are there any drivers for this thing?
Pls help plsssssssssssssssssss
It is not possible to install it like in any other OS.
Im sorry bro but i cant understand you
do you mean i cant install it in other OS-es. I installed it in Windows XP and worked great but MikroTik doesnt recognize it
Seems that it uses Ralink chipset. Are there any drivers fort that kind of chipset? If so pls tell me were can I find them ![]()
Pls help
Router OS doesn’t support this Chipset, and you cant install drivers in ROS.
http://www.mikrotik.com/testdocs/ros/2.9/guide/driverlist.php
I got it! Only these types are available! Thanx so much ![]()
Another little questin. These two cards are in the list:
Dlink DWL-A520
Dlink DWL-G650
but DWL-G510 is not in the list.
What do you think, does MikroTik support this card?
Pls reply ![]()
If this card with Atheros chipset !!
Thank you bro, thank you so muchh ![]()
This means all the chipset types in the list are supported, doesnt it? ![]()
yes , but my advice stick with Atheros chipset
its very stable, cheap and MT support it will (all but i think not new 802.11n)
you can use any cheap card like TP-Link and it will work very well in your solution.
Thank you brother ![]()
So ill buy that DWL-G510 Adapter ![]()
Yeah, ive been using a TP-Link ADSL Router for ages and never had a problem with it an im sure its cheap cuz. my ISP (just like all the others) look only for cheap stuff
but thats worth it ![]()
Another question:
DWL-G510 seems that has a 2dB antenna (as i read in DLink’s site) but there is something else written 15dBm. Does that mean that this card has that power? Can i attach a 15dB omni antenna on it? Will it really be 15dB?
Thank you a lot for your advices and your help ![]()
yes you can if the Dlink antenna is detachable
and your total output power will be 15dBm + 15dBi - Cables and connectors loss
http://www.electro-comm.com/~electr0/cgi-bin/simplewireless.main.cgi
WoooooooooooooooW
That site is amazing
Thank you bro, thank you so much ![]()
I wish you all the best, bye
