Cobalt RaQ 2 - ROS Conversion
Has anyone tried using a Cobalt RaQ 2 with ROS? If so; how successful was the project?
use a RAQ3, RAQ4, RAQ XTR
this models based on a AMD K6 CPU (RAQ3) oder INTEL P3 CPU (RAQ4 / XTR / RAQ550)
Is this really working ? I still have a Raq4i with no function so far :slight_smile: Is the display also working ?
I have a Raq4i and I would like also install Mikrotik, please could anyone tell me how could this be done?
Best regards.
I just bought a Cobalt Qube 3 to install Mikrotik on using a IDE Flash module but i am not sure if it wil ever work because the Qube uses a special bootloader.
Has anyone succesfully used a Cobalt Applicance using Mikrotik?
Tonight i will try to restore the cube tot the Sun default installation after which i can upgrade the rom to support 2.6 kernel and EXT3 file system. I already found out that my 4 port 10/100 nic will not fit in the casing. :confused:
Anybody can update this topic? I tried to put IDE flash card into, but RaQ has
own bootloader, ROS doesnt boot… Anybody has any ideas what to do?
Thanks.
