Hi all,
I need a little help =)
I add an Ip adresse on “Charts”, and and I need ping her… But i don’t know (and not found) how to write the code.
Thanks all
Hi all,
Thanks all
Add a ping probe to a device then create a chart and add the ping probe to the chart.
Lebowski
Thanks for your answer
Because I know that, but, i have 25 device with same name on same submap.
ick
Are each of those pings on a different VPN link? Can you rename those?
Lebowski
Yes they have a different IP, and i can’t change it :
