Code check request.
Hello, I would like someone smarer then I to check and make sure i have this code done right before i put it in the RB493AH.
Suggestions are welcome!!
/ ip firewall mangle
add chain=input in-interface=pppoe-out1 action=mark-connection new-connection-mark=wan1_conn
add chain=input in-interface=pppoe-out2 action=mark-connection new-connection-mark=wan2_conn
add chain=input in-interface=pppoe-out3 action=mark-connection new-connection-mark=wan3_conn
add chain=input in-interface=pppoe-out4 action=mark-connection new-connection-mark=wan4_conn
add chain=output connection-mark=wan1_conn action=mark-routing new-routing-mark=to_wan1
add chain=output connection-mark=wan2_conn action=mark-routing new-routing-mark=to_wan2
add chain=output connection-mark=wan3_conn action=mark-routing new-routing-mark=to_wan3
add chain=output connection-mark=wan4_conn action=mark-routing new-routing-mark=to_wan4
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/0 \
action=mark-connection new-connection-mark=wan1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/1 \
action=mark-connection new-connection-mark=wan2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/2 \
action=mark-connection new-connection-mark=wan3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/3 \
action=mark-connection new-connection-mark=wan4_conn passthrough=yes
add chain=prerouting connection-mark=wan1_conn in-interface=Local action=mark-routing new-routing-mark=to_wan1
add chain=prerouting connection-mark=wan2_conn in-interface=Local action=mark-routing new-routing-mark=to_wan2
add chain=prerouting connection-mark=wan3_conn in-interface=Local action=mark-routing new-routing-mark=to_wan3
add chain=prerouting connection-mark=wan4_conn in-interface=Local action=mark-routing new-routing-mark=to_wan4
/ ip route
add dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_wan1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_wan2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out3 routing-mark=to_wan3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out4 routing-mark=to_wan4 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out2 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out3 distance=3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out4 distance=3 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=pppoe-out1 action=masquerade
add chain=srcnat out-interface=pppoe-out2 action=masquerade
add chain=srcnat out-interface=pppoe-out3 action=masquerade
add chain=srcnat out-interface=pppoe-out4 action=masquerade
Found this code somewhere on the board here a few weeks back and edited it to fit my needs
Also, is there a way to get it to check to see if a link is down/up and adjust accordingly?
TIA
Drew
