Has anyone got any scripts setup using Codeigniter?
I’m in the process of getting a little config panel setup and aperantly this is a good framework to base it on?
Sam
Sam
We have developing Mikrotik RouterOS API Library from Denis Basta (denis.basta@gmail.com) routeros_api class and we change it to our core class with name Mapi_Core. We have been tested with RouterOS version 3 and above. This spark library allow your Mikrotik RouterOS via CodeIgniter Framework for PHP, and we have make it easier than before for access and manipulating Mikrotik RouterOS API with specific method.
If you are CodeIgniter Framework Programmer, you can get Library for CodeIgniter Spark in this link :
Spark Library : http://getsparks.org/packages/mikrotik_api/show
Spark Repository : https://github.com/vthink/mikrotik_api
Documentation : http://doc.vthink.web.id
Updates Info : http://vthink.web.id/index.php/content/categories/21
if you have codeigniter but doesn’t have a spark management package you can install it via terminal with this command :
php -r "$(curl -fsSL http://getsparks.org/go-sparks)"
more information about what is CodeIgniter Spark PHP Framework, please open this link:
http://getsparks.org/install
