Hello!
Am I misunderstanding something or there is no way to have 2 ipv6 gateways to the same gateway, with different weights?
My ISP gives me a valid ipv6 address and I also have a Tunnel Broker 6to4 tunnel.
I would like, for test purpose, to have He as my secondary default gateway. Strange thing that when I add it with a weight equal to 2 (or any number bigger than 1) my routes does not work. It simply ignores my default gateway as if I don’t have any of them.
All works fine with only 1 gateway. After the second, no success. And only get again working when I disable the HE interface. If I only remove the route, it stills not working.
[admin@CUCA] > tool trace 2001:4860:4860::8888
# ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV STATUS
1 100% 2 timeout
2 100% 2 timeout
3 100% 2 timeout
4 100% 2 timeout
5 100% 2 timeout
