Coexistence of RIP and OSPF: how to redistribute default
In my router, RIP and OSPF work simultaneously on different interfaces. I receive default route from OSPF. Then, I need to redistribute it via RIP. How to do it correctly. My RIP config:
      distribute-default: never
     redistribute-static: no
  redistribute-connected: yes
       redistribute-ospf: yes
        redistribute-bgp: no
          metric-default: 1
           metric-static: 1
        metric-connected: 1
             metric-ospf: 1
              metric-bgp: 1
            update-timer: 30s
           timeout-timer: 3m
           garbage-timer: 2m
           routing-table: main
With this config, router installs in RIP table all OSPF routes except default. In OSPF table the default looks like:
 0 0.0.0.0/0          ext-1          101                                       192.168.3.1     ipip-central1
Should I set
distribute-default=if-installed
in RIP and
distribute-default=if-installed-as-type-1
in OSPF?
I run both RIP and OSPF on all my interfaces. OSPF will always be the preferred route, before RIP. Routing on RIP is set on never on every thing except for the router with the actual default route on it. This is set to always.
