Combination Router OS vs Antenna
All,
I have purchased Mikrotik RB411 and RB433,I plan RB411 as AP and RB 433 to share.Additional I have Hyperlink OMNI 15 dbi and the other Grid Sectoral 24 dbi.Honestly requested advise how to the best design relate to an Antenna I have.
connect the antenna to the RouterBOARD :slight_smile: they complement eachother. RouterBOARD can’t work in wireless mode without antenna.
…and then 15db omni to AP(RB411) and 24db grid to client(RB433).
The 433 is a more feature/option rich RB, perhaps you may consider using at for the AP instead.
Thank for your support,I will follow as above mentioned and will keep track what I doing and what the result will be to share later on
