Combine 2 equal ADSL and use 1 ADSL for remote management
I would like to combine 2 24/1Mbps ADSL lines.
IP Config is:
ether1 on 192.168.1.2
ether2 on 192.168.2.2
ether1 connected to adsl router 192.168.1.1
ether2 connected to adsl router 192.168.2.1
I use 192.168.1.1 d-link router with dlinkddns.com and port forward to 192.168.1.2
IP Routes:
destination 0.0.0.0/0 goes to gateway 192.168.1.1 right now with no mangle at all.
The question is: Should I add one more gateway (192.168.2.1) to my default route and that’s it?Will I be able to remote connect to the router with my config of dlinkddns on 192.168.1.1 as I am right now?
Is this going to do the job for equal lines without losing the remote management?
http://forum.mikrotik.com/t/cobine-two-unequal-lines/38834/1
