Combine 2 ISP and use IP Public
Dear, you,
I just started to learn Mikrotik and it really difficult for me. I have a problem that I want to ask you for advice for the config, so I hope you are interested.
I have 2 ISP lines:
ISP 1: IP WAN 1.1.1.0/30 - IP Lan Public 10.10.10.0/29 (Data Rate 7 Mbps)
ISP 2: IP WAN 2.2.2.0/30 - IP Lan Public 10.10.20.0/29 (Data Rate 3 Mbps)
I want to combine 2 ISP lines to 1 line (Data Rate = 7 + 3 = 10 Mbps)
Next, I have 2 VLAN inside
VLAN 1: network 192.168.1.0/24
VLAN 2: network 192.168.2.0/24
How can they be connected to the internet?
How do I config it?
Next, I have the subnets IP Lan Public of the ISP.
I want to use directly 10.10.10.1 for Server 1, 10.10.20.1 for Server 2
How do I config it?
Next, I want Nat one Inside IP LAN to one IP Public
Ex: 192.168.1.2 to 10.10.10.2, 192.168.2.2 to 10.10.20.2
How do I config it?
These are problems I have not done yet.
I look forward to receiving your help.
Finally, Happy new year 2019. Health, fun, and happiness!
Have a look at these documents for reference
https://wiki.mikrotik.com/wiki/Manual:PCC
PCC allows for connections to flow across multiple WAN interfaces
Here is the document for configuring VLANs
https://wiki.mikrotik.com/wiki/Manual:Interface/VLAN
If you are not familiar with Mikrotik platforms, or routing and switching techniques in general, you should always consult the guides and manuals for your product.
Hey
A vlan behaves as any other subnet with regards to routing: you’ll need ip on both vlans on the router and have all devices use router’s ip on vlans as gateway. Router should just forward using normal routing process (+ src-nat see lower).
Subnet
that depends on the subnet definition as it’s done on the isp modem. Within that range the servers will be fine, outside the servers won’t be auto picked up by the modem.
Nat
10.0 is not public ip, it’s also private. Means that ISP will be doing NATting as well for all of your traffic.
To do natting of your internal network, you’ll need to src-nat all traffic leaving the router on the 10. interface to router.
add action=src-nat to-address=<your 10. on isp subnet> chain=src-nat out-interface=<10. subnet interface>
You cannot combine throughput for one session. What you have is redundancy and access to a total throughput of the combined.
