Hello!
I have network setup in 3 step. I’m looking for solution where I need to combine 2 link (Load Balancing) from same LAN network (PPPoE IP Pool 192.168.20.1/24) to get higher bandwidth at other end. Scenario mentioned below and Network Diagram attached with this post.
- Site A has MikroTIk CCR 1009 with LAN IP Pool of 192.168.20.1/24 on Ether 2 and Ether 3 is Slave of Ether 2.
- Site B is connected with wireless link from Ether 3 - Slave - LAN / 50 Mb port.
- Site C is connected with Fiber Cable from Ether 2 / 20 Mb Port.
I need a solution where I want to connect SITE B and SITE C through Wireless with 20 Mb port so total combined bandwidth should be 40 Mb at SITE C (Load Balancing 20 Mb fiber + 20 Mb wireless) without LAN Looping.
What solution I can use? And what Switch or RouterBoard I can use for such a scenario? I did try bonding on RB750 but didn’t work.
Thanks in advance Team.
