Combining two Internet connections to increase the speed
Hey guys
I have 2 internet connections the first is 4 MB and the second is 2MB I wanna merge them to be 6 MB
so I have been searching for answer but didn’t find
Here is some information
first wan1 192.168.1.1 second wan2 192.168.2.1
for the local network I use this ip address 10.1.1.1/24
Plz I need help
https://wiki.mikrotik.com/wiki/Load_Balancing
Technically you cannot MERGE them without the ISP support.
All you can do is to LOAD balance your requests between those 2 internet links using PCC technique in mikrotik.
Mikrotik Wiki & Google is literally filled with such examples. But first read & understand the logic how PCC works in Mikrotik. Without understanding the logic, copy paste won’t give you your desired result :slight_smile:
