What is the expected behavior?
On a CRS326, when plugging copper into a combo port it does not auto-detect the copper when set to “auto”. Not even link lights. Setting the port to copper and everything works fine.
I did find another post stating the author needed to set it to copper as well. And one about using both copper and sfp on the same port causing the sfp to take precedence. Nothing I looked through indicated if this was expected behavior.
Thank you in advance,
