command dude
hi
Why does not the telnet work in dude clinte?
command is:
telnet [Device.FirstAddress] [Device.UserName] [Device.Password]
What should I do?
Hello, alin30!
May you try to add a Telnet-Putty tool?
putty.exe -telnet [Device.FirstAddress]
Thank you!
I know this is an old post but i was having the same issue, and i wanted to thank you!, i installed the Telnet client in windows but for some reason it didn’t work, This fixed my problem, thanks!
