I have a router RB751U-2HnD. Software version - 5.20. I need to manipulate the routes from the script.
I have the following configuration:
[admin@MikroTik] /ip route> print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 8.8.4.4/32 10.10.10.89 1
1 A S ;;; 111
0.0.0.0/0 10.10.10.89 1
2 A S 192.168.7.0/24 192.168.7.1 bridge1 1
3 A S ;;; 222
0.0.0.0/0 94.19.50.65 1
4 A S 192.168.7.0/24 192.168.7.1 bridge1 1
5 A S 212.109.12.45/32 94.19.50.65 1
6 A S ;;; 333
7 DS 0.0.0.0/0 94.19.50.65 2
8 ADC 10.10.10.88/30 10.10.10.90 ether2 0
9 ADC 94.19.50.64/26 94.19.50.81 ether1 0
10 ADC 192.168.7.0/24 192.168.7.1 bridge1 0
[admin@MikroTik] /ip route> print detail
0 A S dst-address=8.8.4.4/32 gateway=10.10.10.89
gateway-status=10.10.10.89 reachable via ether2 distance=1 scope=30
target-scope=10 routing-mark=test_channels
1 A S ;;; 111
dst-address=0.0.0.0/0 gateway=10.10.10.89
target-scope=10 routing-mark=channel2
2 A S dst-address=192.168.7.0/24 pref-src=192.168.7.1 gateway=bridge1
gateway-status=bridge1 reachable distance=1 scope=10 target-scope=10
3 A S ;;; 222
dst-address=0.0.0.0/0 gateway=94.19.50.65
gateway-status=94.19.50.65 reachable via ether1 distance=1 scope=30
target-scope=10 routing-mark=channel1
4 A S dst-address=192.168.7.0/24 pref-src=192.168.7.1 gateway=bridge1
5 A S dst-address=212.109.12.45/32 gateway=94.19.50.65
6 A S ;;; 333
target-scope=10
7 DS dst-address=0.0.0.0/0 gateway=94.19.50.65
gateway-status=94.19.50.65 reachable via ether1 distance=2 scope=30
target-scope=10 vrf-interface=ether1
8 ADC dst-address=10.10.10.88/30 pref-src=10.10.10.90 gateway=ether2
gateway-status=ether2 reachable distance=0 scope=10
9 ADC dst-address=94.19.50.64/26 pref-src=94.19.50.81 gateway=ether1
gateway-status=ether1 reachable distance=0 scope=10
10 ADC dst-address=192.168.7.0/24 pref-src=192.168.7.1 gateway=bridge1
gateway-status=bridge1 reachable distance=0 scope=10
Checks operation of find command:
[admin@MikroTik] /ip route> :put [find]
*6;*1;*3;*4;*2;*7;*5;*30000001;*40138613;*40138737;*40138857
All right, there are all routes
[admin@MikroTik] /ip route> :put [find comment=“111”]
*1
[admin@MikroTik] /ip route> :put [find comment=“222”]
*4
The filter by comment works
[admin@MikroTik] /ip route> :put [find dst-address=“10.10.10.88/30”]
*40138613
The filter by dst-address with dynamic (connected) routes works
[admin@MikroTik] /ip route> :put [find dst-address=“0.0.0.0/0”]
Ooops, empty
[admin@MikroTik] /ip route> :put [find dst-address=“8.8.4.4/32”]
*6
Hmmmm, It’s work
[admin@MikroTik] /ip route> :put [find dst-address=“212.109.12.45/32”]
Empty again.
Can anybody explain this selectivity and the logic of the find?
For example in software version 5.16 there have been similar problems to seek routes. I could find 0.0.0.0/0 but not on other criteria there were similar errors with empty result.
And one more question. What I need to write to the selection criteria for the find command to view only the main table (main)? To view only another table I simple add something like a <routing-mark = “channel1”>. What must I add in find criteria for routes only without mark?
Dmitry
