Is it possible to run a run after reset file not physically located in the mikrotik folder, but rather on your pc?
I would like to connect to the router via serial cable, and do a command line reset with no defaults, and run a setup script located on my pc.
Can this be done?
/system reset-configuration no-defaults=yes skip-backup=yes ???
You can issue that command and then just paste the config into your conection with the serial port.
You mean just paste the text of the script into the console via serial?
Yes, that should work.
Or use an upload function of the terminal program (not X/Y/Z modem of course, but plain upload).
What would the command line for uploading a file from your pc to the mikrotik look like?
pe1chl
May 30, 2016, 11:15am
6
That depends on the operating system that you use and the serial console tool you use with it.
RouterOS has both a FTP server and a FTP client built in.
To use the FTP client you can use the “/tool fetch” command.
See: wiki.mikrotik.com/wiki/Manual:Tools/Fetch
Otherwise you can connect to the router’s FTP server if it is enabled and upload a file to it.
If the file is named “*.auto.rsc”, RouterOS will automatically execute the script inside it.
See: wiki.mikrotik.com/wiki/Manual:Configuration_Management#Importing_Configuration
The “/system reset-configuration” command can also be set to import a script file after reseting.
See: wiki.mikrotik.com/wiki/Manual:Configuration_Management#Configuration_Reset
Do however remember that importing a script automatically in anyway will fail if the script contains any errors.
Possibly the easiest way to do what you are asking, is to place your file on an FTP server and fetch it in the router’s CLI before you reset it.
An example:
# Download configuration file.
/tool fetch mode=ftp address=192.168.1.200 src-path="YourScript.rsc" dst-path="YourScript.rsc"
# If download was successful, reset the configuration and force it to execute the script file.
/system reset-configuration no-defaults=yes skip-backup=yes run-after-reset="YourScript.rsc"
For an exact example, let’s say the file you want to upload to the router via serial is called file.rsc. You are using a windows pc, and file.rsc is located on your desktop. The pc’s IP address is 192.168.156.
What would that code look like?
I don’ think you can actually transfer the file through the serial connection.
I’m trying to paste this script into the router via the serial connection, and I keep getting errors.
What am I doing wrong?
add name=pool1 ranges=192.168.1.2-192.168.1.254
add address-pool=pool1 disabled=no interface=ether2 lease-time=3d name=server1
add address=192.168.1.1/24 interface=ether2 network=192.168.1.0
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=ether1
Maybe this question is super stupid, but what is the errors you are getting? And at which lines?
They are different each time. Can someone try it and see if they are also getting errors?
Please connect via serial and paste it in after a reset.
So, let me just guess.
“No such item”
“Item already exists”
Am I close? I can only really guess while I am not at my desk.
Even if they are different every time, it would help A LOT to know what the errors are and which commands are giving the errors.
Even better if you just copy-paste the console screen here.
no, those are not the errors. I do a complete reset before pasting.
I’m not in my lab so I can’t get you the error info right now.
Please give it a try and see what I mean.
normis
May 31, 2016, 6:00am
15
If you don’t post the actual errors, nobody can help. Hint: the error actually explains what is wrong. Seriously.
I understand. I can’t do it until tomorrow. I am asking if someone can try it to see if they get any errors.
normis
May 31, 2016, 6:07am
17
The above script will only work on a router with zero configuration. Most people here do have already a pool named “pool1” so they will get errors, same as you probably
I only run the script after executing this command:
Another stupid question, what router model are you using?
The router does have two ethernet ports, right?
tabate47:
/ip dhcp-client
There, I can run it all without any errors.
This is however using the terminal in WinBox, but I would be surprised if it is any different on the serial connection.
