Command prompt disappeared
I have version 2.9.7 installed on a RB-532 and when I open a terminal window either from WinBox or via SSH, I get the ASCII-drawn MikroTik banner, but not the command prompt.
I generated the supout file, but I do not know how to attach it here.
Thanks,
juibar
send it to support@mikrotik.com. Remember, that this is not an official support forum!
This usually happens when the router is at 100% cpu. 2.9.7 is a little old too, probably an issue that was fixed since then.
