Hi all.
I’m trying to make simple check at start of my script and if check fail just interrupt script execution. I can’t find a command to do this in manual. Exit, quit or something else? Can somebody help me with this?
:if ( condition = true ) do={
< your code >
Thats it if check fail your code will not be executed
Thank you mrz
But what I actually want to achieve is to make something like:
< command wich brakes execution of script >
I just don’t want to use multiple nested if but if it is the only way, I’ll try.
as far as I know unfortunately nested ifs are the only way. There are no stop script command.
but there could be a workaround:
:if ( condition=true ) do={
/system script job remove [/system script job find script=<script_name>;
not sure if it will work but you can try.
