Hi just a simple question how can i remove a value or delete it.
I my case i will edit the value /interface wireless cap caps-man-names=server1
i am able to edit or to set this but i wont to remove it just like i click on the “arrow up” in the GUI
LG David
/interface wireless cap set caps-man-names=“”
“” are two " , not 4 '
nipfel
October 29, 2024, 2:52pm
3
This solution does not work for /ip firewall nat>
set in-interface=“” produces error “ambiguous value of interface, more than one possible value matches input”
6.49.13 long-term
Guntis
October 29, 2024, 3:07pm
4
You can use:
“/ip firewall nat unset value-name=in-interface”
or
“/ip firewal nat set !in-interface”
The avatar is a cat shitting? Seriously?
Your avatar is shitty and disrespectful to others.
